Is it possible to set a 3rd level chooser (extra modifier key) that is active just for one application and not the full system?
I’d like to have a half-qwerty-like mapping for Krita, so I can have all shortcuts in half the keyboard so they are easier to access with one hand only. I tried setting it to the caps-lock key, but it overwrites another setting I had for it (ESC, which I need most of the time for text editing in Emacs and Vim).
Unless the application allows you to modify internal shortcuts and you don’t use any of the same shortcuts on a system level, the answer is:
No! you can’t do that!
E.G. if the application allows you to re-define Ctrl+Shift+S as “save as”, but you re-define Ctrl+Shift+S as “shutdown system” on a system level, the system will take precedence!
Note: How I get around that is by using the Meta⊞ (aka “the Windows”) key" so:
⊞+Shift+S shuts down the system
Ctrl+Shift+S saves as (for all applications that allow me to change that shortcut)
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
