Hi, I’ve installed multiple window decorations using pamac, since KDE store (Get new window decorations) has always been buggy for me. Two of these are lightly & materia. I’m currently using lightly with materia-dark global theme. Here are the info for those two packages:
materia-kde
$ pacman -Qi materia-kde
Version : 20210410-1
Description : Materia theme for KDE Plasma 5
Architecture : any
URL : https://github.com/PapirusDevelopmentTeam/materia-kde
Licenses : GPL3
Groups : None
Provides : None
Depends On : None
Optional Deps : materia-gtk-theme: Matching GTK theme [installed]
kvantum-theme-materia: Materia theme for Kvantum Qt style (recommended) [installed]
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 3.95 MiB
Packager : Bruno Pagani <archange@archlinux.org>
Build Date : Sat Apr 10 22:22:39 2021
Install Date : Fri May 14 20:28:42 2021
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
lightly-qt
Version : 0.4.1-1
Description : A modern style for qt applications
Architecture : x86_64
URL : https://github.com/Luwx/Lightly
Licenses : GPL
Groups : None
Provides : None
Depends On : None
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : lightly-git
Replaces : None
Installed Size : 1010.06 KiB
Packager : Unknown Packager
Build Date : Thu May 20 17:46:31 2021
Install Date : Thu May 20 17:59:59 2021
Install Script : No
Validated By : None
Here is my system info:
System info
$ inxi -Fxxxzm
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_NZ.UTF-8",
LC_NAME = "en_NZ.UTF-8",
LC_MONETARY = "en_US.UTF-8",
LC_PAPER = "en_NZ.UTF-8",
LC_IDENTIFICATION = "en_NZ.UTF-8",
LC_TELEPHONE = "en_NZ.UTF-8",
LC_MEASUREMENT = "en_001.UTF-8",
LC_TIME = "en_001.UTF-8",
LC_COLLATE = "en_US.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
System: Kernel: 5.4.123-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: HP product: HP Laptop 14-bw0xx v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8324 v: 22.27 serial: <filter> UEFI: AMI v: F.28 date: 04/09/2019
Battery: ID-1: BAT0 charge: 29.0 Wh (91.2%) condition: 31.8/31.8 Wh (100.0%) volts: 16.1 min: 14.6 model: HP Primary
type: Li-ion serial: N/A status: Discharging cycles: 285
Memory: RAM: total: 3.29 GiB used: 1.9 GiB (57.8%)
CPU: Info: Dual Core model: AMD E2-9000e RADEON R2 4 COMPUTE CORES 2C+2G bits: 64 type: MCP arch: Excavator rev: 0
cache: L2: 1024 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 5990
Speed: 1092 MHz min/max: 1100/1500 MHz boost: enabled Core speeds (MHz): 1: 1092 2: 1094
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Sunplus Innovation HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 3-1.3:3 chip-ID: 1bcf:2c9b
class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa s-res: 1366x768 s-dpi: 96
OpenGL: renderer: AMD STONEY (DRM 3.35.0 5.4.123-1-MANJARO LLVM 11.1.0) v: 4.5 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:15b3 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 15h Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.4.123-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8168
v: 8.048.03-NAPI port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: e000 bus-ID: 03:00.0
chip-ID: 8086:24fb class-ID: 0280
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-1.4:4 chip-ID: 8087:0aa7
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 465.76 GiB used: 97.64 GiB (21.0%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPCX-60VHAT0 size: 465.76 GiB speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
Partition: ID-1: / size: 31.37 GiB used: 20.39 GiB (65.0%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 256 MiB used: 84.7 MiB (33.1%) fs: vfat dev: /dev/sda1
ID-3: /home size: 191.97 GiB used: 77.16 GiB (40.2%) fs: ext4 dev: /dev/sda5
Swap: ID-1: swap-1 type: partition size: 5 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda6
Sensors: System Temperatures: cpu: 33.8 C mobo: N/A gpu: amdgpu temp: 33.0 C
Info: Processes: 189 Uptime: 37m wakeups: 1 Init: systemd v: 247 Compilers: gcc: 11.1.0 clang: 11.1.0 Packages: 1604
pacman: 1586 flatpak: 18 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
Here’s my KDE Plasma info:
KDE Plasma Version: 5.21.5
KDE Frameworks Version: 5.82.0
Qt Version: 5.15.2
And here’s my problem:
Issue: Application menu pops up somewhat away from application menu
Observed result: Application menu pops up somewhat away from application menu icon when I’m using materia-dark global theme with materia-dark window decorations. The distance is shown using a green line, which is absent in the 2nd pic.
Expected result: However, it pops just under the icon when I’m using materia-dark global theme with lightly window decorations. I want that to happen in materia-dark aurorae theme too.
What I’ve tried: Searching the internet gave me things like aurorae themes and kde plasma global menu, which do not solve my problem.
I hope my question is clear, English is not my 1st language. Thanks in advance.
