As title says- when I press the meta key for opening the application menu there is about 1 second of delay before it opens.
Directly clicking on the application menu makes it open at expected snappy-ness, though.
Not just visual:
typing straight after pressing meta, all the keys do as they would if I didn’t have the menu open.
when it finally opens, the words start filling in as expected.
System is up-to-date. Changing the kernel does not help nor does turning on/off the compositor. Themes have no effect either.
output of inxi:
Kernel: 5.11.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=b5020253-8d75-4ad1-abef-d3d0c07dffe0 ro quiet apparmor=1
security=apparmor resume=UUID=462e5d82-aebf-4886-8a60-8a8afd2cf5d5
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <filter> UEFI [Legacy]: American Megatrends v: 5220 date: 09/12/2019
RAM: total: 15.63 GiB used: 2.33 GiB (14.9%)
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D L2 cache: 3 MiB
bogomips: 92254
Speed: 1692 MHz min/max: 1550/3850 MHz boost: disabled Core speeds (MHz):
1: 1692 2: 1468 3: 1372 4: 1373 5: 1537 6: 1374 7: 1372 8: 1372 9: 3197
10: 1794 11: 1265 12: 1375
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nouveau v: kernel bus ID: 09:00.0 chip ID: 10de:1b83 class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1494 s-dpi: 96 s-size: 1016x395mm (40.0x15.6")
s-diag: 1090mm (42.9")
Monitor-1: DVI-D-2 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: DP-1 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: NV134 v: 4.3 Mesa 20.3.4 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 09:00.1 chip ID: 10de:10f0
class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0b:00.3 chip ID: 1022:1457 class ID: 0403
Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-3:2 chip ID: 046d:081b class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.11.1-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 03:00.0
chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000
bus ID: 08:00.0 chip ID: 8086:2723 class ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-6:4
chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 350.27 GiB used: 9.23 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS256GSSD370S
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 6KB scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 120GB
size: 111.8 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 00RL scheme: MBR
ID-1: / raw size: 94.6 GiB size: 92.61 GiB (97.90%) used: 9.23 GiB (10.0%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: b5020253-8d75-4ad1-abef-d3d0c07dffe0
ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 462e5d82-aebf-4886-8a60-8a8afd2cf5d5
ID-1: /dev/sda1 maj-min: 8:1 size: 238.47 GiB fs: f2fs label: N/A
uuid: 1add2f54-87f7-42e6-9492-48be6d5fb66f
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-3:2 info: Logitech Webcam C310 type: Video,Audio
Device-2: 1-4:3 info: Xiaomi Mi/Redmi series (MTP) type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s chip ID: 2717:ff40
class ID: 0000 serial: <filter>
Device-3: 1-6:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029 class ID: e001
Device-4: 1-7:5 info: Hoksi DURGOD Taurus K320 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 2f68:0082 class ID: 0300
Device-5: 1-10:6 info: Razer USA Viper (wired) type: Mouse,Keyboard
chip ID: 1532:0078 class ID: 0301
chip ID: 1d6b:0003 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nouveau temp: 49.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Processes: 299 Uptime: 22m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1167 lib: 398 flatpak: 0 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.3.01
This is a new install, and I have not done any tweaking- what do I be missing?
note: there is another small issue i am having todo with the task bar. Im total noob at posting so i wont risk a roast for doing the wrong thing if i can avoid it, so if its a task bar issue i can possibly elaborate further. I have like, totally changed my window manager and backagian, and in the process fixed anything else. The issue with the application menu is still here though.
