Appimage icons no longer showing (Appimage Launcher)
Greetings all,
I noticed over the last few months that Appimage icons from integrated images are no longer showing up.
Any clues as to why that might be happening?
It doesn't affect performance as everything is working fine.
All icons used to show for all appimages a few months ago.
Cura Appimage seems to not be affected.
I'm just wondering, for my knowledge, why something like this would happen.
Any help on this matter would be most appreciated.
Cheers,
AT
This is not unusual behavior for AppimageLauncher when it adds the app to the start-panel. I have seen this behavior in other distros. I'm pretty sure it is a issue with AppimageLauncher itself. Rather than go through the hassle of trying to get it fixed I just download a new icon for the particular application, name it appropriately, save it to a folder i have for them, then right click the start panel and select edit applications, find the app and change it's icon there.
I figured as much. The problem might very well be the launcher. I'm going to try the custom icon method and call it a day. Thanks for the help.
AT
