Hello,
I am trying to get notifications to work on apparmor. That is the last thing I haven’t figured out and couldn’t find anything on this forum nor the arch wiki on how to solve it.
Error message:
[magician@intel-manjaro-kde ~]$ sudo aa-notify
File “/usr/bin/aa-notify”, line 38, in
import notify2
ModuleNotFoundError: No module named ‘notify2’
There is no separate apparmor notify package in the pamac store so it must be a part of the apparmor package?
I have followed this wiki guide:
https://wiki.archlinux.org/title/AppArmor#Installation
At the: ‘‘Create desktop launcher with the below content:’’ part I could not find the specified location so I used the following location:
/home/magician/.config/autostart/
Then I made a file called: apparmor-notify.desktop. It’s content is such as described in the wiki article.
Can someone shine some light on this error message?
Greetings.
Try installing python-notify2
and python-psutil
$ sudo pacman -Syu python-notify2 python-psutil --asdeps
see optional dependencies of apparmor
Optional Deps : perl: for perl bindings
python-notify2: for aa-notify
python-psutil: for aa-notify
ruby: for ruby bindings
Hi,
You are fast. I did install python-notify2 and after a reboot you already responded haha. No error message this time with:
[sudo] wachtwoord voor magician:
usage: aa-notify [-h] [-p] [--display DISPLAY] [-f FILE] [-l] [-s NUM] [-v] [-u USER] [-w NUM] [--debug]
Display AppArmor notifications or messages for DENIED entries.
optional arguments:
-h, --help show this help message and exit
-p, --poll poll AppArmor logs and display notifications
--display DISPLAY set the DISPLAY environment variable (might be needed if sudo resets $DISPLAY)
-f FILE, --file FILE search FILE for AppArmor messages
-l, --since-last display stats since last login
-s NUM, --since-days NUM
show stats for last NUM days (can be used alone or with -p)
-v, --verbose show messages with stats
-u USER, --user USER user to drop privileges to when not using sudo
-w NUM, --wait NUM wait NUM seconds before displaying notifications (with -p)
--debug debug mode
I also changed apparmor-notify.desktop to apparmor-notify.desktop.sh.
And I get the following output with:
[magician@intel-manjaro-kde ~]$ pgrep -ax aa-notify
2161 /usr/bin/python3 /usr/bin/aa-notify -p
I am suppose to get (a lot off) notifications displayed according to the wiki, but so far none… Using firefox with firetools now. So far so good??
Is there a way to test a notification? Have read it somewhere but can’t find it anymore.
Thank you.
Tip: When pasting terminal output on Discourse forums, one can either…
Highlight it and use the Preformatted text </> toolbar button, not the Blockquote " button
Add three backticks ` above and below the text (Markdown):
text
Use HTML:
<pre><code>
text
</pre></code>
Please edit your posts accordingly.
As @Yochanan pointed out to me: install those dependecies as dependencies (use --asdeps
switch). I’ve edited my post accordingly.
If you just need to mark them now after installing, use:
$ sudo pacman -D --asdeps python-notify2 python-psutil
I’m not sure what that’s supposed to accomplish.
The wiki says: you could get alot of notifications depending on configuration.
Thats slightly different.
Will do. Thank you.
Update.
After removing the .sh extension on apparmor-notify.desktop it works as it should. After reboot:
1857 /usr/bin/python3 /usr/bin/aa-notify -p -s 1 -w 60 -f /var/log/audit/audit.log
And once again you beat me to it
