I’m currently having issues using the WAVLINK ug7602hc on my PC, I’m using a Lenovo Legion 5 15ACH6, My Kernel is Linux 6.3.5-2-MANJARO x86_64 i’m running Manjaro KDE . I read somewhere that the displaylink should work with this device. I have followed the steps here Displaylink to the letter, However i still cannot get my monitors up and running, I have tried this on Windows Partition and it works perfectly fine.
Please what information would you require that i share?
dmesg
[ 3392.261131] usb 4-2: new SuperSpeed USB device number 7 using xhci_hcd
[ 3392.278525] usb 4-2: New USB device found, idVendor=090c, idProduct=0768, bcdDevice= 0.01
[ 3392.278537] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3392.278541] usb 4-2: Product: SMI USB Display
[ 3392.278543] usb 4-2: Manufacturer: Silicon_Motion
[ 3392.278546] usb 4-2: SerialNumber: 50EBF69830CF62CD11A30000
[ 3392.437408] usb 4-2: Warning! Unlikely big volume range (=12272), cval->res is probably wrong.
[ 3392.437418] usb 4-2: [9] FU [PCM Playback Volume] ch = 2, val = -4592/7680/1
[ 3392.438957] input: Silicon_Motion SMI USB Display as /devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb4/4-2/4-2:1.2/0003:090C:0768.0011/input/input40
[ 3392.494199] hid-generic 0003:090C:0768.0011: input,hidraw2: USB HID v1.00 Device [Silicon_Motion SMI USB Display] on usb-0000:05:00.4-2/input2
[ 3392.495259] input: Silicon_Motion SMI USB Display as /devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb4/4-2/4-2:1.3/0003:090C:0768.0012/input/input41
[ 3392.550830] hid-generic 0003:090C:0768.0012: input,hidraw3: USB HID v1.00 Device [Silicon_Motion SMI USB Display] on usb-0000:05:00.4-2/input3
I also installed evdi 1.14.0 and displaylink 5.7-1 and displaylink-cobbect 3.3.0-1
Seeing as this isn’t your first time here, you should know this already. but in any case, in order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
yay -S xf86-video-siliconmotion -> No AUR package found for X-ABI-VIDEODRV_VERSION=24.0
-> could not find all required packages: X-ABI-VIDEODRV_VERSION =24.0
