My keyboard habits are as follows:
Switch Caps Lock and Esc
Swap left Alt and left Ctrl
then:
L_Ctrl + H -> Left
L_Ctrl + J -> Down
L_Ctrl + K -> Up
L_Ctrl + L -> Right
L_Ctrl + B -> Ctrl + Left
L_Ctrl + W -> Ctrl + Right
L_Ctrl + num_0 -> Home
L_Ctrl + num_4 -> End
Previously, with setxkbmap, this tool could only finish swap keys. with xmodmap, this tool could only modify the mapping of a single key, but multiple keys could not be implemented.Changing left Ctrl to Mode_Switch does part of the feature, but the original left Ctrl key doesn’t work. If I want to switch input methods with left Ctrl+space, I can’t do it, because the keyboard layout has been broken.
I have also used xbindkeys, sxhkd combined with xdotool, xvkbd, xev, but the experience was very poor. For example, I use xbindkeys with xdotool, if I press Left Ctrl+ H, I can change to Left. However, if I press L_Ctrl+ H all the time, I can only produce a Left key instead of a continuous Left
xvkbd with --xsendevent options can work well in some apps witch is not based on gtk3.
I eventually discovered xkeysnail, a tool that almost perfectly answered my needs, but had a major problem with “libinput Disable While Typing Enabled” function is failed on my touchpad.
my xnailkeys config is
import re
from xkeysnail.transform import *
define_modmap({
# 交换 ESC 和 Caps Lock
Key.CAPSLOCK: Key.ESC,
Key.ESC: Key.CAPSLOCK,
# 交换 左Alt 和 左Ctrl
Key.LEFT_CTRL: Key.LEFT_ALT,
Key.LEFT_ALT: Key.LEFT_CTRL
define_keymap(None, {
K("LC-h"): K("LEFT"),
K("LC-j"): K("DOWN"),
K("LC-k"): K("UP"),
K("LC-l"): K("RIGHT"),
K("LC-b"): K("C-LEFT"),
K("LC-w"): K("C-RIGHT"),
K("LC-KEY_0"): K("home"),
K("LC-KEY_4"): K("end")
}, "vim-like keys")
define_keymap(re.compile("firefox"), {
K("RC-KEY_0"): K("LM-KEY_0"),
K("RC-KEY_1"): K("LM-KEY_1"),
K("RC-KEY_2"): K("LM-KEY_2"),
K("RC-KEY_3"): K("LM-KEY_3"),
K("RC-KEY_4"): K("LM-KEY_4"),
K("RC-KEY_5"): K("LM-KEY_5"),
K("RC-KEY_6"): K("LM-KEY_6"),
K("RC-KEY_7"): K("LM-KEY_7"),
K("RC-KEY_8"): K("LM-KEY_8"),
K("RC-KEY_9"): K("LM-KEY_9"),
}, "firefox")
Is there any other way?
