Hello,
As the title say; Any application to edit GDM? Just to change the background.
regards,
Hello,
regards,
I have checked d-conf, but couldn’t find anything that could look like background change.
https://wiki.archlinux.org/index.php/GDM#Log-in_screen_background_image
Not an application, but there you have a quite manual process to do it in theory. At the end of the paragraph there is a link to a script that automates the process, but I haven’t tested it myself. If you backup the binary file, you should be all right anyway.
Hi,
Loginized is the solution. See it. It is also available in AUR. It works under Xorg and Wayland and with Gnome 3.38.2 on Manjaro. I use it everyday…
Thanks!
