Any advantage to kernel upgrade?
I have Manjaro-i3wm on a 13 year old Toshiba laptop. That laptop has an old Pentium Dual T3400 CPU and 4GB RAM with a 128GB SSD. It runs great for its age.
The kernel version is 4.14.219-1-MANJARO.
I don’t run any fancy new hardware on this machine. It’s for fairly basic computing. I keep the system up-to-date. I never have any issues updating nor any error messages.
I realize this is a fairly old kernel now but “it just works”. I see no reason to upgrade the kernel given my situation, but if someone has a good reason for doing so please let me know what it is and I might consider it.
I see no compelling reason to upgrade the kernel until you no longer receive security updates.
Kernel 4.14 will be supported until January 2024. After that date, I would recommend switching.
“Anything that worked on Linux once, will work forever” – try proving this statement wrong searching the whole internet. Upgrading kernels isn’t necessary if you don’t use newer hardware and are using a supported version. But if you occasionally use new hardware or software you will need to update you’re kernel. Again, it’s a totally personal choice.
yours is fine. the only “upgrade” to old processors came with 5.9 with FSGSBASE instructions, and that only apply to 3rd Generation Intel Core processors (Ivy Bridge) and after
