Another lightdm issue, tried older solutions with no luck
Hi all,
Can’t get into the Gui at all and looked at 4 other solutions with no luck. I don’t understand why I can’t uninstall.
Any tips?
h ttp://imgur.com/gallery/2Nzj9go
What happens when you log in and execute startx ?
This is what I get, doesn’t look too good?
h ttp://imgur.com/gallery/4vKRwQa
You may have seen my recent post about lightdm, do you have snapshots or backups that you can use?
Although I fixed the problem, it’s a temp fix, and I would like to be able to install updates again with no worries. I might break it on purpose tomorrow and try to work it out. I’ll follow this thread, and post anything I find too.
