Very Disingenuous IMHO to split post onto another thread for disagreeing with your point of view. I am shocked and disappointed. To then place it in non technical section and remove all reference to RAM and LXDE adds insult to injury - perhaps that was your intent - hardly a mistake. Very bad show
It was not off topic as your excuse says - Head Post By: Fan4_metal
Hi, I’ve noticed that my Manjaro Gnome uses under 600 Mb on a fresh start on my VM. I thought Gnome was much heavier, but this is comparable to “light” DEs like XFCE.
So I was right on topic with both quoted RAM figures and light DEs - LXDE
Thanks - does that give green light for me to write a post on RAM and the slowdown… even if it interrupts the space time continuum - quoting the Wiki “A space–time Trade off or time–memory trade-off in computer science is a case where an algorithm…”
Hey - I am 71 and retired but an engineer’s brain can never switch off
Paid a friend and colleague years back to build me a SolidWorks 3D CAD tower rather than just buy a Dell Workstation. I still use it - Er? and XP-Pro…! Test all Linux distros on it too.
Wow - never seen such a readout - i9 sounds expensive?
Have you ever maxed system out or got anywhere near?
Is it you that I have to thank for that 112MiB RAM used on Trisquel-mini LXDE…?
It was recorded on that very old SolidWorks 3D CAD 4GiB RAM tower that does not even have an “i” number
So you would agree that Trisquel and Trisquel-mini have more functionality as well as better efficiency?
Just searched for Trisquel-mini and there is just this post.
There are no RAM discussion comments under the few results found by searching - Trisquel.
So where did you have those discussions to get way past that?
Thanks
This is Manjaro forum - we don’t discuss trisquel here - and we are past discussion on RAM usage. If you want to learn about Linux and RAM - see https://linuxatemyram.com
You could search the archive https://archived.forum.manjaro.org (one or two years ago a major breakdown caused the forum to be rebuilt - only text is available)
Is this against any particular community rule or is it your special rule?
Just searched for “Debian” and lost count of over 50 results - please explain.
Just searched for “Mint” and lost count of over 50 results - please explain.
Just searched for “PopOS” and lost count of over 50 results - please explain.
Just searched for “Fedora” and lost count of over 50 results - please explain.
Just searched for “ubuntu” and lost count of over 50 results - please explain.
Just searched for et etc etc…please explain?
Is there a special rule concerning discussion of Trisquel, Trisquel-mini and Triskel?
Nothing will ever be learned, nothing will be advanced, by ignoring evidence.
Yes; been to that link many times - it is so incomplete in content?
This is Manjaro forum and the members contribute knowledge about Manjaro to other Manjaro users.
I didn’t say anything about rules - I merely stated a fact - I haven’t seen any mention of Trisquel during my 5 year stay on Manjaro.
Now that you mention rules - one of them is - no support for other distributions.
Other GNU/Linux distributions often use different package management, package versions, repositories and configuration, constituting support for such projects quite impossible on the Manjaro forums. Community technical support is intended for the Manjaro Linux distribution and packages available in the Arch Package Repository and the Arch User Repository. Threads concerning issues with, and requesting support for, completely separate distributions or operating systems are strongly discouraged and may be closed. Threads requesting support for distributions that are upstream or downstream from Manjaro will likely be allowed so long as you’ve exhausted that distribution’s own support services first. - Forum Rules - Manjaro
So you have no problem with discussing any other distro in relation to Manjaro - or do you?
I am obviously not seeking support about Trisquel.
It should be quite clear that I am contributing to Manjaro with better information on RAM utilization - It is no good burying your head in the sand or pretending to be more efficient with a headless window manager. Cheers
I don’t pretend anything - I don’t assume anything
Such topics are bikeshed discussions and not fruitful in any way.
Threads stating the equivalent of “there is a problem with the Manjaro system and methodology, we need to discuss it” have been repeatedly proven ineffective and inflammatory and will usually be locked after a warning from the moderation team. If you have identified a systemic issue, find a solution that works for you, implement it, then post.
Furthermore, questioning or discussing the methods used by the Manjaro Linux development team will be monitored closely and locked if deemed unhelpful and/or unproductive. Harsh, unproductive criticism is also uncalled for.
If you have a question regarding Manjaro development, please ensure that your topic poses a specific question and be open-minded to responses. If possible, provide a solution or partial solution. Submitting code and patches for discussion is always more pragmatic than asking others to do it for you. - Forum Rules - Manjaro
I Andy1, am being effectively stopped from posting here as the other poster is a moderator.
Can I humbly apologize to the 255+ readers for being unable to read my comments?
Thanks for your interest.
