Hi all,
I am having issues with installing Manjaro via Architect. The installation fails when starting the installation of Manjaro desktop environment. The ISO I am using is the latest XFCE from the Manjaro downloads (20.2.1). I am installing architect through this iso rather than the dedicated architect ISO as this is the more up to date version.
When I update mirror list during the preinstall I do get some verbose messaging but I do no think it is related, but will add them below as reference.
The error I get is Error [install basepkgs][255]
The terminal then show more information after this error:
Installation Failed
==> Creating install root at /mnt
-> Installing packages to /mnt
downloading core.db...
downloading extra.db...
downloading community.db...
downloading multilib.db...
:: There are 24 members in group base-devel:
:: Repository core
1) autoconf 2) automake 3) binutils 4) bison 5) fakeroot 6) file 7) findutils 8) flex 9) gawk 10) gcc 11) gettext 12) grep 13) groff 14) gzip 15) libtool 16) m4 17) make 18) pacman 19) patch 20) pkgconf 21) sed 22) sudo 23) texinfo 24) which
Enter a selection (default=all): error: target not found: linux-latest
==> ERROR: Failed to install packages to new root
The following is my m-a.log
:: manjaro-architect 0.9.34-5 ::
03/21/21 12:35:55 system: UEFI, init: systemd nw-client: nmtui
03/21/21 12:36:00 set LANG=en_US.UTF-8
03/21/21 12:36:00 set font ter-124n
03/21/21 12:36:00 loadkeys us
03/21/21 12:36:26 refresh database error: failed retrieving file 'core.db' from mirror.catn.com : Failed to connect to mirror.catn.com port 80: No route to host
03/21/21 12:36:39 loadkeys uk
03/21/21 12:37:13 rm 2 on /dev/nvme0n1
03/21/21 12:37:13 rm 1 on /dev/nvme0n1
03/21/21 12:37:13 /dev/nvme0n1 is
03/21/21 12:37:13 /dev/nvme0n1 mklabel gpt
03/21/21 12:37:13 create ESP on /dev/nvme0n1
03/21/21 12:37:13 set boot flag for /dev/nvme0n1
03/21/21 12:37:13 create ext3 100% on /dev/nvme0n1
03/21/21 12:37:21 --------- [lsblk] ------------
03/21/21 12:37:21 /dev/sda1 16M
03/21/21 12:37:21 /dev/sda2 1.8T
03/21/21 12:37:21 /dev/sdb1 2.7G
03/21/21 12:37:21 /dev/sdb2 4M
03/21/21 12:37:21 /dev/nvme0n1p1 512M
03/21/21 12:37:21 /dev/nvme0n1p2 465.3G
03/21/21 12:37:21 already mounted: sdb
03/21/21 12:37:21 ignore crypted:
03/21/21 12:37:21 in partitions delete item /dev/sdb1 no: 4 / 5
03/21/21 12:37:21 partitions: /dev/sda1 16M /dev/sda2 1.8T /dev/sdb2 4M /dev/nvme0n1p1 512M /dev/nvme0n1p2 465.3G
03/21/21 12:37:21 in partitions delete item /dev/sdb2 no: 4 / 5
03/21/21 12:37:21 partitions: /dev/sda1 16M /dev/sda2 1.8T /dev/nvme0n1p1 512M /dev/nvme0n1p2 465.3G
03/21/21 12:37:31 mount /dev/nvme0n1p2 as mkfs.ext4 -q.
03/21/21 12:37:31 create mountpoint /mnt
03/21/21 12:37:37 mount /dev/nvme0n1p2 noatime
03/21/21 12:37:41 Swapfile fallocate
03/21/21 12:37:41 Swapfile chmod
03/21/21 12:37:41 Swapfile mkswap
03/21/21 12:37:41 Swapfile swapon
03/21/21 12:37:41 already mounted: sdb
nvme0n1p2
03/21/21 12:37:51 mkfs.vfat -F32 /dev/nvme0n1p1
03/21/21 12:37:52 create /mnt/boot/efi
03/21/21 12:37:52 mount /dev/nvme0n1p1 /mnt/boot/efi
03/21/21 12:41:21 refresh pacman-keys
03/21/21 12:42:27 selected: "yay + base-devel" linux-lts linux-latest linux511 linux512
03/21/21 12:42:27 modules: KERNEL-headers
03/21/21 12:42:32 selected: [Manjaro-i3]
03/21/21 12:42:35 filter_packages
03/21/21 12:42:36 selected 'minimal' profile
03/21/21 12:42:37 packages to install: accountsservice acpi acpid alsa-firmware alsa-plugins alsa-utils amd-ucode arandr autoconf automake avahi b43-fwcutter base-devel bash binutils bison bmenu btrfs-progs bzip2 clipit coreutils cpupower crda cronie cryptsetup device-mapper dfc dhclient dhcpcd diffutils dmidecode dmraid dnsmasq dosfstools e2fsprogs ecryptfs-utils efibootmgr epdfview exfat-utils f2fs-tools fakeroot file filesystem findutils flex gawk gcc-libs gcolor2 gettext glibc gnome-keyring grep groff gvfs gvfs-afc gvfs-gphoto2 gvfs-mtp gvfs-smb gzip htop i3-default-artwork inetutils intel-ucode inxi iproute2 iputils jfsutils json-c kvantum-manjaro less libtool licenses lightdm-slick-greeter linux-latest linux511 linux512 logrotate lvm2 lxappearance lxinput m4 maia-console make man-db man-pages manjaro-browser-settings manjaro-firmware manjaro-hotfixes manjaro-i3-settings manjaro-ranger-settings manjaro-release manjaro-system manjaro-zsh-config markdown_previewer mdadm memtest86+ mesa-demos mhwd mhwd-db mkinitcpio-openswap mlocate mobile-broadband-provider-info moc modemmanager morc_menu mousepad nano ncdu netctl network-manager-applet networkmanager networkmanager-openconnect networkmanager-openvpn networkmanager-pptp networkmanager-vpnc nfs-utils nss-mdns ntfs-3g ntp openresolv openssh os-prober p7zip pacman palemoon-bin pamac patch patchutils pciutils pcmanfm perl perl-file-mimeinfo polkit-gnome powertop procps-ng psmisc qt5-styleplugins qt5ct ranger reiserfsprogs rsync s-nail sbxkb screenfetch sed shadow spectre-meltdown-checker speedtest-cli squashfs-tools sudo sysfsutils syslog-ng systemd systemd-fsck-silent systemd-sysvcompat tar terminus-font texinfo tlp tree ttf-dejavu ufw upower usbutils util-linux vi vi viewnior vim volumeicon w3m wget which wmutils wpa_supplicant xautolock xdg-user-dirs xdg-utils xdotool xf86-input-elographics xf86-input-evdev xf86-input-libinput xf86-input-void xfce4-power-manager xfsprogs xorg-server xorg-twm xorg-xhost xorg-xinit xorg-xkill xorg-xprop xterm xz yay zensu
03/21/21 12:42:44 ERROR [install basepkgs][255]
A snippet of the verbose mirror refresh during preinstall looks like this (I think there are no issues here but not 100%)
gpg: key 7EFD567D4C7EA887: "Ionut Biru (Arch Linux Master Key) <ionut@master-key.archlinux.org>" not changed
gpg: key A04F9397CDFD6BB0: "Dan McGee (Arch Linux Master Key) <dan@master-key.archlinux.org>" not changed
gpg: key 3348882F6AC6A4C2: 4 signatures not checked due to missing keys
gpg: key 3348882F6AC6A4C2: "Pierre Schmitz (Arch Linux Master Key) <pierre@master-key.archlinux.org>" not changed
gpg: key A88E23E377514E00: 4 signatures not checked due to missing keys
gpg: key A88E23E377514E00: "Florian Pritz (Arch Linux Master Key) <florian@master-key.archlinux.org>" not changed
gpg: key 9B729B06A680C281: 4 signatures not checked due to missing keys
gpg: key 9B729B06A680C281: "Bartłomiej Piotrowski (Arch Linux Master Key) <bpiotrowski@master-key.archlinux.org>" not changed
gpg: key D6D055F927843F1C: 1 signature not checked due to a missing key
gpg: key D6D055F927843F1C: "Levente Polyak (Arch Linux Master Key) <anthraxx@master-key.archlinux.org>" not changed
gpg: key BA1DFB64FFF979E7: 3 signatures not checked due to missing keys
gpg: key BA1DFB64FFF979E7: "Allan McRae (Arch Linux Master Key) <allan@master-key.archlinux.org>" not changed
gpg: key 9D4C5AA15426DA0A: no user ID for key signature packet of class 13
gpg: key 9D4C5AA15426DA0A: 15 duplicate signatures removed
Thanks for any help
