So Manjaro crashed again…
A lot of processes couldn’t be stopped, i had to force reset it.
Booted great after though. Weird.
Started out with Brave crashing, it just displayed a black void, no window borders, nothing, just black.
And looking-glass couldn’t start.
Here’s a wetransfer of journalctl --no-pager -p 3
. I outputted it to a file cause it’s huge, too big for forums and over 512 kb for pastebin…
It’s from last few days of use.
inxi -Fza
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=27a6f9c0-8b45-42c5-85e1-be095307048f rw rootflags=subvol=@
amdgpu.gpu_recovery=1 audit=0
resume=UUID=b58bc35c-1a93-4c4c-a1ec-5eefe535dea6 udev.log_priority=3
amd_iommu=on vfio-pci.ids=1002:6658,1002:aac0
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <superuser required>
UEFI: American Megatrends LLC. v: P2.30 date: 02/24/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2545 high: 3991 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 2985
3: 3900 4: 1400 5: 2998 6: 1400 7: 2402 8: 2894 9: 3991 10: 2934 11: 2845
12: 1400 bogomips: 93459
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Bonaire XTX [Radeon R7 260X/360] vendor: PC Partner / Sapphire
driver: vfio-pci v: N/A alternate: radeon,amdgpu arch: GCN-2
code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 1002:6658 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm)
built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1,HDMI-A-1 empty: DP-2 bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 34.0 C
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: AOC Q3279WG5B serial: <filter> built: 2020 res: 2560x1440 dpi: 90
gamma: 1.2 size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9
modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: AOC Q3279WG5B
serial: <filter> built: 2020 res: 2560x1440 dpi: 90 gamma: 1.2
size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.9-1-MANJARO) direct render: Yes
Device-1: AMD Tobago HDMI Audio [Radeon R7 360 / R9 OEM]
vendor: PC Partner / Sapphire driver: vfio-pci alternate: snd_hda_intel
bus-ID: 3-2.2:4 pcie: chip-ID: 1235:8200 class-ID: 0103 speed: Unknown
lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1
chip-ID: 1002:aac0 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Focusrite-Novation Scarlett 2i4 USB type: USB
driver: snd-usb-audio
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: JACK v: 1.9.21 running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-2.1:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 698.65 GiB used: 418.72 GiB (59.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: SBI02102 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-1: / raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
used: 418.72 GiB (93.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
ID-4: /var/log raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.5 GiB used: 2 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 33.0 C mobo: 31.0 C gpu: amdgpu temp: 35.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1112 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
fan-7: 0
Processes: 340 Uptime: 11h 17m wakeups: 0 Memory: 30.73 GiB
used: 7.51 GiB (24.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1865 libs: 504 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.24
Also, every time i reset it, or shut down, it keeps writing “watchdog did not stop”. It didn’t do that before.
Also, side note - is there a way to delete unnecesary stuff that might be filling my drive space but it’s not really needed? My drive keeps filling up and i’m not really doing much to it, it just has less and less space for some reason, not sure why.
