I started update process of Manjaro and got a long freeze. Pressed hard reset button. After that I got stuck on black screen instead of login, Ctrl+Alt+F3 doesn’t work.
Booted from Live USB, manjaro-chroot -a into my installed system. I tried to pacman -Syyuu but pacman was dead silent and I just got a new line inside terminal. Further investigation led me to a fact, that pacman inside /usr/bin and /bin of mounted system has a 0 bytes size. From this moment I don’t know what to do and how to rescue the system. Pacman-mirrors is 0 bytes too.
Exctracted, got two libraries (libarchive and gpgme) “file too short” error, extracted them too, but pacman can’t synchronize mirrors now. Pacman-mirrors gives me some syntax errors, but I’m not motivated to rescue system anymore, thanks for you help.
