无法启动anconda内的spyder!
Fontconfig error: Cannot load default config file
Qt WebEngine ICU data not found at /build/anaconda/pkg/anaconda/opt/anaconda/resources. Trying parent directory...
Qt WebEngine ICU data not found at /build/anaconda/pkg/anaconda/opt/anaconda. Trying application directory...
Qt WebEngine ICU data not found at /opt/anaconda/libexec. Trying fallback directory... The application MAY NOT work.
Path override failed for key base::DIR_QT_LIBRARY_DATA and path '/home/geek/.QtWebEngineProcess'
Installed Qt WebEngine locales directory not found at location /build/anaconda/pkg/anaconda/opt/anaconda/translations/qtwebengine_locales. Trying application directory...
Qt WebEngine locales directory not found at location /opt/anaconda/libexec/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
Path override failed for key ui::DIR_LOCALES and path '/home/geek/.QtWebEngineProcess'
[1029/030644.593167:ERROR:icu_util.cc(178)] Invalid file descriptor to ICU data received.
[1029/030644.593251:FATAL:content_main_runner.cc(691)] Check failed: base::i18n::InitializeICU().
#0 0x7f861769f0be
#1 0x7f86176b16c2
#2 0x7f8617688068
#3 0x7f8617683519
#4 0x7f861703e49a QtWebEngine::processMain()
#5 0x560790523d74
#6 0x7f86153c3153 __libc_start_main
#7 0x560790523dd4
[2151:2151:1029/030644.854700:FATAL:zygote_host_impl_linux.cc(182)] Check failed: ReceiveFixedMessage(fds[0], kZygoteBootMessage, sizeof(kZygoteBootMessage), &boot_pid).
系统: ManjaroGnome 18.1
谢谢大家帮忙看看!
一样的问题,我也无法启动anaconda自带的spyder,实在要用,你直接用pacman单独装一个spyder吧
