Anbox Setup Help
Hi, I just finished setting up my Manjaro Today, so everything is fresh and I believe it to be good.
Now I wanted to setup Anbox, so I can keep using Android Apps after ditching my Android Phone.
I was following this Guide and I manage to reach to the point of running install-playstore.sh so I could use Google Services.
Then as instructed in the guide, restart the 2 mentioned services there. But after running Anbox again, Google Playstore is not in the Applist. so I cannot enable Google Play Services.
Now, I'm stuck just to having an existing Anbox that I can't use without Google Services. What should I do then?
Note:
When I was prompted which anbox-image to use when installing from pacman, I have some of these choises:
  1. anbox-image 2. anbox-image-gapps 3. anbox-image-gapps-rooted 4..... something like houdini....
I chose 1
I am planning to install it again with anbox-image-gapps, but I am already far ahead in the steps, and I don't know if I can do that.
They all provide anbox-image, so whichever you choose to install will replace the current one.
Be warned, Anbox is in an alpha stage and rarely works.
I am on The Step on Installing Apps, that is Step 2:
I manage to run the install-playstore.sh but after restarting the services, and after running anbox.
Google Playstore is still not there.
I guess it has something with the install-playstore.sh contents
set -e
OPENGAPPS_RELEASEDATE="20180706"
OPENGAPPS_FILE="open_gapps-x86_64-7.1-mini-$OPENGAPPS_RELEASEDATE.zip"
OPENGAPPS_URL="https://github.com/opengapps/x86_64/releases/download/$OPENGAPPS_RELEASEDATE/$OPENGAPPS_FILE"
HOUDINI_URL="http://dl.android-x86.org/houdini/7_y/houdini.sfs"
HOUDINI_SO="https://github.com/Rprop/libhoudini/raw/master/4.0.8.45720/system/lib/libhoudini.so"
WORKDIR="$(pwd)/anbox-work"
check if script was started with BASH
if [ ! "$(ps -p $$ -oargs= | awk '{print $1}' | grep -E 'bash$')" ]; then
echo "Please use BASH to start the script!"
exit 1
fi
check if user is root
if [ "$(whoami)" != "root" ]; then
echo "Sorry, you are not root. Please run with sudo $0"
exit 1
fi
check if lzip is installed
if [ ! "$(which lzip)" ]; then
echo -e "lzip is not installed. Please install lzip.\nExample: sudo apt install lzip"
exit 1
fi
check if squashfs-tools are installed
if [ ! "$(which mksquashfs)" ] || [ ! "$(which unsquashfs)" ]; then
echo -e "squashfs-tools is not installed. Please install squashfs-tools.\nExample: sudo apt install squashfs-tools"
exit 1
else
MKSQUASHFS=$(which mksquashfs)
UNSQUASHFS=$(which unsquashfs)
fi
check if wget is installed
if [ ! "$(which wget)" ]; then
echo -e "wget is not installed. Please install wget.\nExample: sudo apt install wget"
exit 1
else
WGET=$(which wget)
fi
check if unzip is installed
if [ ! "$(which unzip)" ]; then
echo -e "unzip is not installed. Please install unzip.\nExample: sudo apt install unzip"
exit 1
else
UNZIP=$(which unzip)
fi
check if tar is installed
if [ ! "$(which tar)" ]; then
echo -e "tar is not installed. Please install tar.\nExample: sudo apt install tar"
exit 1
else
TAR=$(which tar)
fi
use sudo if installed
if [ ! "$(which sudo)" ]; then
SUDO=""
else
SUDO=$(which sudo)
fi
echo $WORKDIR
if [ ! -d "$WORKDIR" ]; then
mkdir "$WORKDIR"
fi
cd "$WORKDIR"
if [ -d "$WORKDIR/squashfs-root" ]; then
$SUDO rm -rf squashfs-root
fi
get image from anbox
cp /var/lib/anbox/android.img .
$SUDO $UNSQUASHFS android.img
get opengapps and install it
cd "$WORKDIR"
if [ ! -f ./$OPENGAPPS_FILE ]; then
$WGET -q --show-progress $OPENGAPPS_URL
$UNZIP -d opengapps ./$OPENGAPPS_FILE
fi
cd ./opengapps/Core/
for filename in *.tar.lz
do
$TAR --lzip -xvf ./$filename
done
cd "$WORKDIR"
$SUDO cp -r ./$(find opengapps -type d -name "PrebuiltGmsCore") ./squashfs-root/system/priv-app/
$SUDO cp -r ./$(find opengapps -type d -name "GoogleLoginService") ./squashfs-root/system/priv-app/
$SUDO cp -r ./$(find opengapps -type d -name "Phonesky") ./squashfs-root/system/priv-app/
$SUDO cp -r ./$(find opengapps -type d -name "GoogleServicesFramework") ./squashfs-root/system/priv-app/
cd ./squashfs-root/system/priv-app/
$SUDO chown -R 100000:100000 Phonesky GoogleLoginService GoogleServicesFramework PrebuiltGmsCore
load houdini and spread it
cd "$WORKDIR"
if [ ! -f ./houdini.sfs ]; then
$WGET -q --show-progress $HOUDINI_URL
mkdir -p houdini
$SUDO $UNSQUASHFS -f -d ./houdini ./houdini.sfs
fi
$SUDO cp -r ./houdini/houdini ./squashfs-root/system/bin/
$SUDO cp -r ./houdini/xstdata ./squashfs-root/system/bin/
$SUDO chown -R 100000:100000 ./squashfs-root/system/bin/houdini ./squashfs-root/system/bin/xstdata
$SUDO $WGET -q --show-progress -P ./squashfs-root/system/lib/ $HOUDINI_SO
$SUDO chown -R 100000:100000 ./squashfs-root/system/lib/libhoudini.so
$SUDO mkdir -p ./squashfs-root/system/lib/arm
$SUDO cp -r ./houdini/linker ./squashfs-root/system/lib/arm
$SUDO cp -r ./houdini/*.so ./squashfs-root/system/lib/arm
$SUDO cp -r ./houdini/nb ./squashfs-root/system/lib/arm/
$SUDO chown -R 100000:100000 ./squashfs-root/system/lib/arm
add houdini parser
mkdir -p ./squashfs-root/system/etc/binfmt_misc
echo ":arm_dyn:M::\x7f\x45\x4c\x46\x01\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x03\x00\x28::/system/bin/houdini:" >> ./squashfs-root/system/etc/binfmt_misc/arm_dyn
echo ":arm_exe:M::\x7f\x45\x4c\x46\x01\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x02\x00\x28::/system/bin/houdini:" >> ./squashfs-root/system/etc/binfmt_misc/arm_exe
$SUDO chown -R 100000:100000 ./squashfs-root/system/etc/binfmt_misc
add features
C=$(cat <<-END
\n
\n
\n
\n
\n
\n
\n
\n
\n
\n
\n
END
C=$(echo $C | sed 's///\//g')
C=$(echo $C | sed 's/"/\"/g')
$SUDO sed -i "/</permissions>/ s/.*/${C}\n&/" ./squashfs-root/system/etc/permissions/anbox.xml
make wifi and bt available
$SUDO sed -i "/<unavailable-feature name="android.hardware.wifi" />/d" ./squashfs-root/system/etc/permissions/anbox.xml
$SUDO sed -i "/<unavailable-feature name="android.hardware.bluetooth" />/d" ./squashfs-root/system/etc/permissions/anbox.xml
set processors
ARM_TYPE=",armeabi-v7a,armeabi"
$SUDO sed -i "/^ro.product.cpu.abilist=x86_64,x86/ s/$/${ARM_TYPE}/" ./squashfs-root/system/build.prop
$SUDO sed -i "/^ro.product.cpu.abilist32=x86/ s/$/${ARM_TYPE}/" ./squashfs-root/system/build.prop
$SUDO echo "persist.sys.nativebridge=1" >> ./squashfs-root/system/build.prop
enable opengles
$SUDO echo "ro.opengles.version=131072" >> ./squashfs-root/system/build.prop
#squash img
cd "$WORKDIR"
rm android.img
$SUDO $MKSQUASHFS squashfs-root android.img -b 131072 -comp xz -Xbcj x86
update anbox image
cd /var/lib/anbox
mv android.img android_bkup.img
mv "$WORKDIR/android.img" android.img
I just checked the very first link in the .sh File
"Page not Found"
I guess I have to hit the wiki. I wish I could comprehend how to properly install it.
