Anbox not starting up
Anbox was working just fine and then this error came up a couple days later when I run try to run anbox:
anbox: error while loading shared libraries: libboost_log.so.1.75.0: cannot open shared object file: No such file or directory
Either you did not reboot the system after the update, or you have mixed external repositories. On Manjaro all branches the boost-libs is at version 1.76 hence only libboost_log.so.1.76.0 exists … Maybe anbox needs a rebuild.
Thanks for the tip!
Rebuilding it got it to work!
