Hi, i am new to linux . I have 5.9 kernel running and fish as default shell. I wanted to install anbox but when i install its module with yay -S anbox-module-dkms-git it comes an error
-> Could not find all required packages: anbox-module-dkms-git (Target)
using dkms also i was not able to install binder and ashmem module.
pls help me
This package no longer exists in the AUR, use the 5.10 kernel and follow the new procedures to install/use Anobox in the 5.10+ kernels
Greetings.
5.10 crashed on my system
When ever I use 5.10 it Show black screen
The 5.9 kernel also works with the new procedure, with no need for dkms modules.
Greetings.
I was not able to enable binder and ashmem module using modprode or dkms
It gives error Module binder-linux not found in directory /lib/modules/5.9.16.1-MANJARO
I think I need those modules plz help
Welcome to the forum!
Please see the following forum rules;
This is a support forum, not an instant messenger. Please don’t post multiple times in row. Instead, you can edit your existing post for a short time.
Thread tidied.
Ok sorry, plz rply
Before using the modprobe command, do the steps in Mounting binderfs, and read all the information, if you follow them, Anbox will work.
Greetings.
@tioguda I was not able Mount it I think I need to have ashmem and binder module plz tell me How I install them
I also have this issue. I can’t install linux-zen because it’s not found (not in manjaro repos?) It seems like the only things I’m missing are the two kernel modules, notably ashmem and binder.
btw I use 5.10.36-2-MANJARO
The kernel must support Anbox modules, no extra modules are needed. If the kernel supports Anbox, follow these steps.
If you used the above commands and got errors, your kernel probably doesn’t support Anbox.
Note: At the moment Anbox only works with lxc 4.0.6, the version in the repository is currently incompatible.
i just lower my kernel and install modules
