Battery doesn’t charge (though it shows the charging symbol, the % goes down)
But if it shutdown and start the laptop, then the charging works fine… (so the hardware seems fine)
Started observing this yesterday, 3 times in last 24 hrs (my last update was 4 days ago)
I put my laptop to sleep most of the time rather than shutdown
below is the tlp-stat output while its working (should have taken a copy before restart, will do once i see it again)
~ sudo tlp-stat --battery ✔
--- TLP 1.4.0 --------------------------------------------
+++ Battery Care
Plugin: lenovo
Supported features: charge threshold
Driver usage:
* vendor (ideapad_laptop) = active (charge threshold)
Parameter value range:
* STOP_CHARGE_THRESH_BAT0: 0(off), 1(on) -- battery conservation mode
/sys/bus/platform/drivers/ideapad_acpi/VPC2004:00/conservation_mode = 0 (100%)
+++ Battery Status: BAT0
/sys/class/power_supply/BAT0/manufacturer = SMP
/sys/class/power_supply/BAT0/model_name = L19M4PF1
/sys/class/power_supply/BAT0/cycle_count = 748
/sys/class/power_supply/BAT0/energy_full_design = 70000 [mWh]
/sys/class/power_supply/BAT0/energy_full = 57710 [mWh]
/sys/class/power_supply/BAT0/energy_now = 16630 [mWh]
/sys/class/power_supply/BAT0/power_now = 29951 [mW]
/sys/class/power_supply/BAT0/status = Charging
Charge = 28.8 [%]
Capacity = 82.4 [%]
