I click anbox in the menu and I get a starting screen but it goes a way after a while and it seems like nothing happens. I’m pretty sure I followed all the indications.
Kernel: 5.10.36-2-MANJARO
I have the following installed:
$ sudo pacman -Q | grep anbox
anbox-git 1:r1346.7d1930c-1
anbox-image 1:2018.07.19-1
I did this:
mkdir /dev/binderfs
mount -t binder binder /dev/binderfs
Added this to /etc/fstab
binder /dev/binderfs binder nofail 0 0
Also did this:
systemctl enable anbox-container-manager.service
systemctl enable systemd-networkd anbox-container-manager
I did this later on as well:
systemctl --user enable --now anbox-session-manager.service
My /dev
looks like this:
$ ls -1 /dev/{ashmem,binder}
ls: cannot access '/dev/binder': No such file or directory
/dev/ashmem
$ ls -1 /dev/{ashmem,binderfs}
/dev/ashmem
/dev/binderfs:
binder
binder-control
hwbinder
vndbinder
Running anbox session-manager
returns the following:
[ 2021-05-22 08:12:23] [client.cpp:48@start] Failed to start container: Failed to start container: Failed to set config item lxc.group.devices.deny
[ 2021-05-22 08:12:23] [session_manager.cpp:164@operator()] Lost connection to container manager, terminating.
[ 2021-05-22 08:12:23] [daemon.cpp:61@Run] Container is not running
terminate called after throwing an instance of 'boost::wrapexcept<boost::exception_detail::error_info_injector<boost::log::v2_mt_posix::system_error> >'
what(): Failed to set TLS value: Invalid argument
Stack trace (most recent call last) in thread 3666:
Am I missing something or did I miss a step?
