An EFI system partition is necessary to start manjaro
#1
Hello Linux fans.
I have currently a dual boot system , windows 8 and linux mint 18. It is UEFI and boots correctly
When I attempt to install manjaro from usb stick and chose the manual partition features
I set sda10 as root and sda11 as /home
When I click install I get a warning
“An EFI system partition is necessary to start manjaro”
The thing is that I do have and EFI system partition. gparted image from linux mint
#2
Do you actually set the mount point for your EFI partition as /boot/efi? IIRC the installer won’t do that automatically.
#3
Yes you should make sure it is selected as the ESP (but do not format it)
#4
Got it. Installing without the efi warning. Fingers crossed;)
#5
Yesss! Now triple booting ok. Thanks for the help.
