Under 5.11.10-1-MANJARO i let the computer working and return after a few hours, but there was no video signal. I SSH into the computer remotely, it was working, i have not seen any dmesg and journalctl issues, maybe i had wrong command and dmesg shown only most recent log lines. After i terminated apps and sent reboot command, the display started showing shutting down lines. Now i am booted back to report this issue and dmesg showing interesting red line:
amdgpu: Unsupported power profile mode 0 on RENOIR
rest of the red lines was also on older kernel, but i had no serious issue with graphics, except the issue on older kernel 5.10.23-1-MANJARO: XFCE and all apps terminated, drm:amdgpu_job_timedout [amdgpu] VLC; GPU reset
log lines on 5.11.10-1-MANJARO
$ sudo dmesg|grep -Ei “amd|gpu|failed|failure|error”;inxi -Gazy
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=… rw cryptdevice=UUID=… root=/dev/mapper/luks-… apparmor=1 security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
[ 0.000000] AMD AuthenticAMD
[ 0.004787] RAMDISK: [mem 0x3606f000-0x3702efff]
[ 0.004821] ACPI: SSDT 0x0000000084BF3000 007229 (v02 AMD AmdTable 00000002 MSFT 04000000)
[ 0.004823] ACPI: IVRS 0x0000000084BF2000 0000D0 (v02 AMD AmdTable 00000001 AMD 00000000)
[ 0.004856] ACPI: VFCT 0x0000000084BC7000 00D484 (v01 HPQOEM SLIC-BPC 00000001 AMD 31504F47)
[ 0.004858] ACPI: SSDT 0x0000000084BC3000 0034A8 (v01 AMD AmdTable 00000001 INTL 20160527)
[ 0.004863] ACPI: SSDT 0x0000000084BFC000 0000BF (v01 AMD AmdTable 00001000 INTL 20160527)
[ 0.004865] ACPI: SSDT 0x0000000084BBF000 001405 (v01 AMD AmdTable 00000001 INTL 20160527)
[ 0.004867] ACPI: SSDT 0x0000000084BB9000 005354 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.004869] ACPI: CRAT 0x0000000084BB8000 000F28 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.004871] ACPI: CDIT 0x0000000084BB7000 000029 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.203827] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=… rw cryptdevice=UUID=…:luks-… root=/dev/mapper/luks-… apparmor=1 security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
[ 0.354477] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.462710] smpboot: CPU0: AMD Ryzen 7 PRO 4750GE with Radeon Graphics (family: 0x17, model: 0x60, stepping: 0x1)
[ 0.462843] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.515721] ACPI BIOS Error (bug): Failure creating named object [_GPE._L00], AE_ALREADY_EXISTS (20201113/dswload2-326)
[ 0.515734] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20201113/psobject-220)
[ 0.516274] ACPI BIOS Error (bug): Could not resolve symbol [_SB.I2CD], AE_NOT_FOUND (20201113/dswload2-162)
[ 0.516278] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20201113/psobject-220)
[ 1.764889] pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
[ 1.767293] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.767298] pci 0000:00:00.2: AMD-Vi: Extended features (0x206d73ef22254ade):
[ 1.767305] AMD-Vi: Interrupt remapping enabled
[ 1.767305] AMD-Vi: Virtual APIC enabled
[ 1.767306] AMD-Vi: X2APIC enabled
[ 1.767549] AMD-Vi: Lazy IO/TLB flushing enabled
[ 1.768455] amd_uncore: 4 amd_df counters detected
[ 1.768480] amd_uncore: 6 amd_l3 counters detected
[ 1.770000] perf: AMD IBS detected (0x000003ff)
[ 1.788170] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel jroedel@suse.de
[ 1.816449] RAS: Correctable Errors collector initialized.
[ 4.561582] ata6: failed to resume link (SControl 0)
[ 13.647154] spl: module verification failed: signature and/or required key missing - tainting kernel
[ 14.908716] EDAC amd64: F17h_M60h detected (node 0).
[ 14.908912] EDAC amd64: Node 0: DRAM ECC disabled.
[ 14.918774] hp_wmi: query 0x4 returned error 0x5
[ 14.932634] hp_wmi: query 0xd returned error 0x5
[ 14.939944] hp_wmi: query 0x1b returned error 0x5
[ 15.021812] EDAC amd64: F17h_M60h detected (node 0).
[ 15.021871] EDAC amd64: Node 0: DRAM ECC disabled.
[ 15.116068] EDAC amd64: F17h_M60h detected (node 0).
[ 15.116118] EDAC amd64: Node 0: DRAM ECC disabled.
[ 15.281578] EDAC amd64: F17h_M60h detected (node 0).
[ 15.281643] EDAC amd64: Node 0: DRAM ECC disabled.
[ 15.433061] EDAC amd64: F17h_M60h detected (node 0).
[ 15.433111] EDAC amd64: Node 0: DRAM ECC disabled.
[ 15.433916] [drm] amdgpu kernel modesetting enabled.
[ 15.434070] amdgpu: Topology: Add CPU node
[ 15.434188] fb0: switching to amdgpudrmfb from EFI VGA
[ 15.434317] amdgpu 0000:0a:00.0: vgaarb: deactivate vga console
[ 15.434468] amdgpu 0000:0a:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 15.435560] amdgpu 0000:0a:00.0: amdgpu: Fetched VBIOS from VFCT
[ 15.435563] amdgpu: ATOM BIOS: 113-RENOIR-026
[ 15.449612] amdgpu 0000:0a:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
[ 15.449615] amdgpu 0000:0a:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 15.449617] amdgpu 0000:0a:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 15.449905] [drm] amdgpu: 512M of VRAM memory ready
[ 15.449908] [drm] amdgpu: 3072M of GTT memory ready.
[ 15.449910] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 15.573266] EDAC amd64: F17h_M60h detected (node 0).
[ 15.573314] EDAC amd64: Node 0: DRAM ECC disabled.
[ 15.692898] EDAC amd64: F17h_M60h detected (node 0).
[ 15.692959] EDAC amd64: Node 0: DRAM ECC disabled.
[ 15.893105] EDAC amd64: F17h_M60h detected (node 0).
[ 15.893163] EDAC amd64: Node 0: DRAM ECC disabled.
[ 15.999450] EDAC amd64: F17h_M60h detected (node 0).
[ 15.999486] EDAC amd64: Node 0: DRAM ECC disabled.
[ 16.049878] EDAC amd64: F17h_M60h detected (node 0).
[ 16.049918] EDAC amd64: Node 0: DRAM ECC disabled.
[ 16.106120] EDAC amd64: F17h_M60h detected (node 0).
[ 16.106168] EDAC amd64: Node 0: DRAM ECC disabled.
[ 16.172596] EDAC amd64: F17h_M60h detected (node 0).
[ 16.172635] EDAC amd64: Node 0: DRAM ECC disabled.
[ 16.239247] EDAC amd64: F17h_M60h detected (node 0).
[ 16.239305] EDAC amd64: Node 0: DRAM ECC disabled.
[ 16.293385] EDAC amd64: F17h_M60h detected (node 0).
[ 16.293446] EDAC amd64: Node 0: DRAM ECC disabled.
[ 16.338220] amdgpu 0000:0a:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 16.358227] amdgpu 0000:0a:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 16.359068] amdgpu 0000:0a:00.0: amdgpu: SMU is initialized successfully!
[ 16.359195] EDAC amd64: F17h_M60h detected (node 0).
[ 16.359236] EDAC amd64: Node 0: DRAM ECC disabled.
[ 16.392764] snd_hda_intel 0000:0a:00.1: bound 0000:0a:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 16.425024] Virtual CRAT table created for GPU
[ 16.425649] EDAC amd64: F17h_M60h detected (node 0).
[ 16.425686] EDAC amd64: Node 0: DRAM ECC disabled.
[ 16.425744] amdgpu: Topology: Add dGPU node [0x1636:0x1002]
[ 16.425754] amdgpu 0000:0a:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
[ 16.426432] fbcon: amdgpudrmfb (fb0) is primary device
[ 16.563170] amdgpu 0000:0a:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 16.595062] amdgpu 0000:0a:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 16.595067] amdgpu 0000:0a:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 16.595069] amdgpu 0000:0a:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 16.595070] amdgpu 0000:0a:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 16.595071] amdgpu 0000:0a:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 16.595073] amdgpu 0000:0a:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 16.595074] amdgpu 0000:0a:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 16.595075] amdgpu 0000:0a:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 16.595076] amdgpu 0000:0a:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 16.595077] amdgpu 0000:0a:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 16.595079] amdgpu 0000:0a:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 16.595080] amdgpu 0000:0a:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[ 16.595082] amdgpu 0000:0a:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[ 16.595083] amdgpu 0000:0a:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[ 16.595084] amdgpu 0000:0a:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[ 16.597421] [drm] Initialized amdgpu 3.40.0 20150101 for 0000:0a:00.0 on minor 0
[ 17.425730] amdgpu 0000:0a:00.0: amdgpu: Unsupported power profile mode 0 on RENOIR
[ 19.579543] audit: type=1103 audit(1618523774.272:91): pid=2188 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘op=PAM:setcred grantors=? acct=“user” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed’Graphics:
Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 0a:00.0 chip-ID: 1002:1636 class-ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.10-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.1 direct render: Yes
