AMDGPU improvements for Manjaro OUTDATED
#827
@Tids I see to your git commits that you upgrade the mhwd-addon-amdgfx-hwe PKGBUILD (20170604, 20170615, etc).
Why don’t you push these changes into the repositories, because I’m with mhwd-addon-amdgfx-hwe 20161231-1 yet.
#828
Isn’t this already implemented in manjaro/mhwd-db? What’s the difference now?
#829
Because I really dont have any testing time and if my code is broken, also no time for a fast fixup :frowning: Whats right now in my git is completely untested :disappointed_relieved:
part of it. the amdgpu-experimental stuff will stay in my package for a bit longer. Luckily the experimental PCIIDs have already moved to mhwd. So less work on this part.
#830
@Tids @Chazy
Hello, how can I do to uninstall amdgpu and install radeon driver ?.
I try with:
1: Create blacklist for amdgpu with /etc/modprobe.d/amdgpu_blacklist.conf
"Blacklist amdgpu".
2: Load module radeon with /etc/modules-load.d/radeon.conf
"Radeon".
3: Uninstall xf86-video-amdgpu.
4: Install video-ati.
5: Run mkinitcpio -P
But after doing this now I get error:
"Failed to start simple desktop display manager"
I reinstalled AMDGPU and it works without problems, but I want to go back to radeon or if there is a possibility to run the HDMI Audio. Thank you
#831
What is your graphicscard? Only GCN 1.0 and 1.1 are able to switch between radeon AND amdgpu experimental. All other chips are only supported in radeon OR amdgpu.
#832
@Tids My graphics card is Sapphire R9 270x 2Gb GDDR5.
So, if I install AMDGPU I can not go back to radeon ?. I have to say that probe the game ARK Survival Evolve and with the radeon driver walked at 45 FPS, but it was unplayable, and closed. With AMDGPU I work between 35-45 FPS, but it goes much more fluid and does not close, you can play without problems. If it were possible to use HDMI audio with AMDGPU I would like to, but for the moment I will continue with AMDGPU and use PC audio. regards
#833
@Fedex15 why not use a dedicated sound system for gaming? instead of the built-in speakers from the tv/monitor you’re using? I’ll never understand why’s so important hdmi audio for gaming, when the audio quality is mediocre at best (compared with a cheap 50-60 usd 5.1 sound system from creative for example).
#834
@Chazy I have the pc connected to the monitor and the tv. I use the monitor to navigate, games, etc, and I use the tv to watch netflix, movies, etc, but for now I will use the speakers. Thank you
#835
Of course you can switch back ba undo everything you did to get amdgpu support in :joy:
You can also use the amd staging kernel from
[mesa-git]
Server = http://pkgbuild.com/~lcarlier/$repo/$arch
repo, that has enabled the DC patchset, and so HDMI-Audio. Of course all the manjaro made kernel modules are not compatible with it, so you need to build them by yourself (for example the virtualbox one).
#836
Hi Tids, what would your recommendation be, stay with the current kernel or test the kernel amd staging ?. I have no idea how to test the kernel that you tell me, for now I’m still with the AMDGPU driver that has given me better performance in the games and I use the pc computer sound. With that kernel you tell me, you can turn on HDMI audio using AMDGPU ?. Thank you
#837
Yes. That should work. And thats probably what i would do. Depends on what gives me the best performance. :smirk:
#838
Hi again, I’m stuck with the catalyst drivers, I try with ati drivers but not work (AMD, proprietary or open source drivers not work). I followed step by step what have done @FedEx15 (AMDGPU improvements for Manjaro OUTDATED) to install the amdgpu drivers and install without any problem, the system starts in the LXDM without problem but after a couple of seconds the monitor is without signal as if disconnected, and when I start at the terminal the cursor is flashing. Check the videos:
lxdm
terminal
Happened with all kernels that I have installed: 4.9, 4.10, 4.11, the Xorg.0.file - https://pastebin.com/wZ0qZaBk
My card is a HD7850 (GCN 1.0)
#839
@Tids. Hi tids, install amd-staging-kernel by following these instructions:
1- Edit /etc/pacman.conf by adding these lines:
[mesa-git]
SigLevel = PackageOptional
Server = https://pkgbuild.com/~lcarlier/$repo/$arch
2- Update the repositories with “pacman -Syyu”
3- Install linux-amd-staging and linux-amd-staging-headers
4- Update grub.
Then start from the grub with the amd-staging kernel, but do not go beyond the following screen:
I’m with the 4.9 kernel now with no problems, which may be that it’s past that it does not work ?. Thank you
#840
@Tids. This is the log for Xorg with kernel amd staging:
[    11.963] (--) Log file renamed from "/var/log/Xorg.pid-775.log" to "/var/log/Xorg.0.log"
[    11.963]
X.Org X Server 1.19.3
Release Date: 2017-03-15
[    11.963] X Protocol Version 11, Revision 0
[    11.963] Build Operating System: Linux 4.9.11-1-ARCH x86_64
[    11.963] Current Operating System: Linux federico-pc 4.11.0-3-amd-staging-git #1 SMP PREEMPT Sun Jun 18 14:56:37 -03 2017 x86_64
[    11.963] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux-amd-staging-git root=UUID=4e0f658e-8c9f-49ae-afc0-c21ac2ba42eb rw quiet resume=UUID=99960f52-c381-44ba-a322-6ef742ca3aaf
[    11.963] Build Date: 07 April 2017  05:42:48PM
[    11.963]
[    11.963] Current version of pixman: 0.34.0
[    11.963] 	Before reporting problems, check http://wiki.x.org
[    11.963] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.963] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jun 18 12:34:20 2017
[    11.963] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.963] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.963] (==) No Layout section.  Using the first Screen section.
[    11.963] (==) No screen section available. Using defaults.
[    11.963] (**) |-->Screen "Default Screen Section" (0)
[    11.963] (**) |   |-->Monitor "<default monitor>"
[    11.963] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    11.963] (**) |   |-->Device "AMD"
[    11.963] (==) No monitor specified for screen "Default Screen Section".
[    11.963] (==) Automatically adding devices
[    11.963] (==) Automatically enabling devices
[    11.963] (==) Automatically adding GPU devices
[    11.963] (==) Automatically binding GPU devices
[    11.963] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.963] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[    11.963] 	Entry deleted from font path.
[    11.963] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    11.963] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    11.963] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    11.963] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    11.963] (==) FontPath set to:
	/usr/share/fonts/misc/,
	/usr/share/fonts/TTF/,
	/usr/share/fonts/OTF/
[    11.963] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.963] (II) The server relies on udev to provide the list of input devices.
[    11.963] (II) Loader magic: 0x822d60
[    11.963] (II) Module ABI versions:
[    11.963] 	X.Org ANSI C Emulation: 0.4
[    11.963] 	X.Org Video Driver: 23.0
[    11.963] 	X.Org XInput driver : 24.1
[    11.963] 	X.Org Server Extension : 10.0
[    11.964] (++) using VT number 1
[    11.964] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    11.964] (--) PCI:*(0:1:0:0) 1002:6810:174b:e270 rev 0, Mem @ 0xe0000000/268435456, 0xf7e00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[    11.964] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    11.964] (II) LoadModule: "glx"
[    11.964] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.965] (II) Module glx: vendor="X.Org Foundation"
[    11.965] 	compiled for 1.19.3, module version = 1.0.0
[    11.965] 	ABI class: X.Org Server Extension, version 10.0
[    11.965] (II) LoadModule: "amdgpu"
[    11.965] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[    11.965] (II) Module amdgpu: vendor="X.Org Foundation"
[    11.965] 	compiled for 1.19.3, module version = 1.3.0
[    11.965] 	Module class: X.Org Video Driver
[    11.965] 	ABI class: X.Org Video Driver, version 23.0
[    11.965] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[    11.965] (II) [KMS] drm report modesetting isn't supported.
[    11.965] (EE) Screen 0 deleted because of no matching config section.
[    11.965] (II) UnloadModule: "amdgpu"
[    11.965] (EE) Device(s) detected, but none match those in the config file.
[    11.965] (EE)
Fatal server error:
[    11.965] (EE) no screens found(EE)
[    11.965] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    11.965] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    11.965] (EE)
[    11.965] (EE) Server terminated with error (1). Closing log file.
#841
looks like Kernel Modesettings are inactive for some reason…
can you do:
zgrep -i "amdgpu" /proc/config.gz
grep amdgpu /proc/modules
it could be that this kernel is build without amdgpu experimental support, wich would be bad.
#842
@Tids Here the screen:
This is the log for Kernel 4.9:
[    11.415] (--) Log file renamed from "/var/log/Xorg.pid-614.log" to "/var/log/Xorg.0.log"
[    11.424]
[    11.424] X Protocol Version 11, Revision 0
[    11.424] Build Operating System: Linux 4.9.11-1-ARCH x86_64
[    11.424] Current Operating System: Linux federico-pc 4.9.31-1-MANJARO #1 SMP PREEMPT Wed Jun 7 19:39:15 UTC 2017 x86_64
[    11.424] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9-x86_64 root=UUID=4e0f658e-8c9f-49ae-afc0-c21ac2ba42eb rw quiet resume=UUID=99960f52-c381-44ba-a322-6ef742ca3aaf
[    11.424] Build Date: 07 April 2017  05:42:48PM
[    11.424]
[    11.424] Current version of pixman: 0.34.0
[    11.424] 	Before reporting problems, check http://wiki.x.org
[    11.424] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.424] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jun 18 16:16:45 2017
[    11.434] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.434] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.463] (==) No Layout section.  Using the first Screen section.
[    11.463] (==) No screen section available. Using defaults.
[    11.463] (**) |-->Screen "Default Screen Section" (0)
[    11.463] (**) |   |-->Monitor "<default monitor>"
[    11.463] (==) No device specified for screen "Default Screen Section".
[    11.463] (**) |   |-->Device "AMD"
[    11.463] (==) No monitor specified for screen "Default Screen Section".
[    11.463] (==) Automatically adding devices
[    11.463] (==) Automatically enabling devices
[    11.463] (==) Automatically adding GPU devices
[    11.463] (==) Automatically binding GPU devices
[    11.463] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.497] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[    11.497] 	Entry deleted from font path.
[    11.497] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    11.497] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    11.497] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    11.497] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    11.497] (==) FontPath set to:
[    11.497] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.497] (II) The server relies on udev to provide the list of input devices.
[    11.497] (II) Loader magic: 0x822d60
[    11.497] (II) Module ABI versions:
[    11.497] 	X.Org ANSI C Emulation: 0.4
[    11.497] 	X.Org Video Driver: 23.0
[    11.497] 	X.Org XInput driver : 24.1
[    11.497] 	X.Org Server Extension : 10.0
[    11.498] (++) using VT number 1
[    11.498] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    11.498] (II) xfree86: Adding drm device (/dev/dri/card0)
[    11.499] (--) PCI:*(0:1:0:0) 1002:6810:174b:e270 rev 0, Mem @ 0xe0000000/268435456, 0xf7e00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[    11.499] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    11.499] (II) LoadModule: "glx"
[    11.499] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.545] (II) Module glx: vendor="X.Org Foundation"
[    11.545] 	compiled for 1.19.3, module version = 1.0.0
[    11.545] 	ABI class: X.Org Server Extension, version 10.0
[    11.545] (II) LoadModule: "amdgpu"
[    11.545] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[    11.559] (II) Module amdgpu: vendor="X.Org Foundation"
[    11.559] 	compiled for 1.19.3, module version = 1.3.0
[    11.559] 	Module class: X.Org Video Driver
[    11.559] 	ABI class: X.Org Video Driver, version 23.0
[    11.559] (II) AMDGPU: Driver for AMD Radeon:
[    11.559] (II) [KMS] Kernel modesetting enabled.
[    11.559] (II) AMDGPU(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    11.559] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[    11.559] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    11.559] (==) AMDGPU(0): Default visual is TrueColor
[    11.559] (**) AMDGPU(0): Option "AccelMethod" "glamor"
[    11.559] (**) AMDGPU(0): Option "DRI" "3"
[    11.559] (**) AMDGPU(0): Option "TearFree" "true"
[    11.559] (==) AMDGPU(0): RGB weight 888
[    11.559] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[    11.559] (--) AMDGPU(0): Chipset: "AMD Radeon(TM) HD 8800 Series" (ChipID = 0x6810)
[    11.559] (II) Loading sub module "fb"
[    11.559] (II) LoadModule: "fb"
[    11.559] (II) Loading /usr/lib/xorg/modules/libfb.so
[    11.568] (II) Module fb: vendor="X.Org Foundation"
[    11.568] 	compiled for 1.19.3, module version = 1.0.0
[    11.568] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.568] (II) Loading sub module "dri2"
[    11.568] (II) LoadModule: "dri2"
[    11.568] (II) Module "dri2" already built-in
[    12.255] (II) Loading sub module "glamoregl"
[    12.255] (II) LoadModule: "glamoregl"
[    12.255] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    12.283] (II) Module glamoregl: vendor="X.Org Foundation"
[    12.283] 	compiled for 1.19.3, module version = 1.0.0
[    12.283] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    12.283] (II) glamor: OpenGL accelerated X.org driver based.
[    12.354] (II) glamor: EGL version 1.4 (DRI2):
[    12.378] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[    12.378] (**) AMDGPU(0): TearFree property default: on
[    12.378] (II) AMDGPU(0): KMS Pageflipping: enabled
[    12.407] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[    12.467] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[    12.498] (II) AMDGPU(0): Output DVI-I-0 has no monitor section
[    12.499] (II) AMDGPU(0): Output DVI-D-1 has no monitor section
[    12.530] (II) AMDGPU(0): EDID for output DisplayPort-0
[    12.589] (II) AMDGPU(0): EDID for output HDMI-A-0
[    12.589] (II) AMDGPU(0): Manufacturer: GSM  Model: 1  Serial#: 16843009
[    12.589] (II) AMDGPU(0): Year: 2015  Week: 1
[    12.589] (II) AMDGPU(0): EDID Version: 1.3
[    12.589] (II) AMDGPU(0): Digital Display Input
[    12.589] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 160  vert.: 90
[    12.589] (II) AMDGPU(0): Gamma: 2.20
[    12.589] (II) AMDGPU(0): No DPMS capabilities specified
[    12.589] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    12.589] (II) AMDGPU(0): First detailed timing is preferred mode
[    12.589] (II) AMDGPU(0): redX: 0.640 redY: 0.330   greenX: 0.300 greenY: 0.600
[    12.589] (II) AMDGPU(0): blueX: 0.150 blueY: 0.060   whiteX: 0.312 whiteY: 0.329
[    12.589] (II) AMDGPU(0): Supported established timings:
[    12.589] (II) AMDGPU(0): 720x400@70Hz
[    12.589] (II) AMDGPU(0): 640x480@60Hz
[    12.589] (II) AMDGPU(0): 800x600@60Hz
[    12.589] (II) AMDGPU(0): 1024x768@60Hz
[    12.589] (II) AMDGPU(0): Manufacturer's mask: 0
[    12.589] (II) AMDGPU(0): Supported standard timings:
[    12.589] (II) AMDGPU(0): #0: hsize: 640  vsize 480  refresh: 60  vid: 16433
[    12.589] (II) AMDGPU(0): #1: hsize: 800  vsize 600  refresh: 60  vid: 16453
[    12.589] (II) AMDGPU(0): #2: hsize: 1024  vsize 768  refresh: 60  vid: 16481
[    12.589] (II) AMDGPU(0): #3: hsize: 1152  vsize 864  refresh: 60  vid: 16497
[    12.589] (II) AMDGPU(0): #4: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    12.589] (II) AMDGPU(0): Supported detailed timing:
[    12.589] (II) AMDGPU(0): clock: 148.5 MHz   Image Size:  160 x 90 mm
[    12.589] (II) AMDGPU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[    12.589] (II) AMDGPU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    12.589] (II) AMDGPU(0): clock: 85.5 MHz   Image Size:  160 x 90 mm
[    12.589] (II) AMDGPU(0): h_active: 1360  h_sync: 1424  h_sync_end 1536 h_blank_end 1792 h_border: 0
[    12.589] (II) AMDGPU(0): v_active: 768  v_sync: 771  v_sync_end 777 v_blanking: 795 v_border: 0
[    12.589] (II) AMDGPU(0): Ranges: V min: 58 V max: 62 Hz, H min: 30 H max: 83 kHz, PixClock max 165 MHz
[    12.589] (II) AMDGPU(0): Monitor name: LG TV
[    12.589] (II) AMDGPU(0): clock: 74.2 MHz   Image Size:  800 x 450 mm
[    12.589] (II) AMDGPU(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[    12.589] (II) AMDGPU(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[    12.589] (II) AMDGPU(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[    12.589] (II) AMDGPU(0): clock: 74.2 MHz   Image Size:  708 x 398 mm
[    12.589] (II) AMDGPU(0): h_active: 1280  h_sync: 1720  h_sync_end 1760 h_blank_end 1980 h_border: 0
[    12.589] (II) AMDGPU(0): Number of EDID sections to follow: 1
[    12.589] (II) AMDGPU(0): EDID (in hex):
[    12.589] (II) AMDGPU(0): 	00ffffffffffff001e6d010001010101
[    12.589] (II) AMDGPU(0): 	0119010380a05a780aee91a3544c9926
[    12.589] (II) AMDGPU(0): 	0f5054a1080031404540614071408180
[    12.589] (II) AMDGPU(0): 	010101010101023a801871382d40582c
[    12.589] (II) AMDGPU(0): 	4500a05a0000001e662150b051001b30
[    12.589] (II) AMDGPU(0): 	40703600a05a0000001e000000fd003a
[    12.589] (II) AMDGPU(0): 	3e1e5310000a202020202020000000fc
[    12.589] (II) AMDGPU(0): 	004c472054560a202020202020200140
[    12.589] (II) AMDGPU(0): 	020322f14e109f041305140302122021
[    12.589] (II) AMDGPU(0): 	2215012615075009570767030c002000
[    12.589] (II) AMDGPU(0): 	801e011d8018711c1620582c250020c2
[    12.589] (II) AMDGPU(0): 	3100009e011d007251d01e206e285500
[    12.589] (II) AMDGPU(0): 	20c23100001e023a801871382d40582c
[    12.589] (II) AMDGPU(0): 	4500a05a0000001e011d00bc52d01e20
[    12.589] (II) AMDGPU(0): 	b8285540c48e2100001e000000000000
[    12.589] (II) AMDGPU(0): 	00000000000000000000000000000015
[    12.589] (--) AMDGPU(0): HDMI max TMDS frequency 150000KHz
[    12.589] (II) AMDGPU(0): Printing probed modes for output HDMI-A-0
[    12.589] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080"x30.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080"x25.0   74.25  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080"x30.0   74.18  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1360x768"x60.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1152x864"x60.0   81.58  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz)
[    12.589] (II) AMDGPU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "720x576i"x50.0   13.50  720 732 795 864  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    12.589] (II) AMDGPU(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    12.620] (II) AMDGPU(0): EDID for output DVI-I-0
[    12.620] (II) AMDGPU(0): Manufacturer: GSM  Model: 5790  Serial#: 16843009
[    12.620] (II) AMDGPU(0): Year: 2010  Week: 10
[    12.620] (II) AMDGPU(0): EDID Version: 1.3
[    12.620] (II) AMDGPU(0): Digital Display Input
[    12.620] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 51  vert.: 29
[    12.620] (II) AMDGPU(0): Gamma: 2.20
[    12.620] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[    12.620] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    12.620] (II) AMDGPU(0): First detailed timing is preferred mode
[    12.620] (II) AMDGPU(0): redX: 0.628 redY: 0.348   greenX: 0.345 greenY: 0.615
[    12.620] (II) AMDGPU(0): blueX: 0.153 blueY: 0.057   whiteX: 0.313 whiteY: 0.329
[    12.620] (II) AMDGPU(0): Supported established timings:
[    12.620] (II) AMDGPU(0): 720x400@70Hz
[    12.620] (II) AMDGPU(0): 640x480@60Hz
[    12.620] (II) AMDGPU(0): 640x480@75Hz
[    12.620] (II) AMDGPU(0): 800x600@56Hz
[    12.620] (II) AMDGPU(0): 800x600@60Hz
[    12.620] (II) AMDGPU(0): 800x600@75Hz
[    12.620] (II) AMDGPU(0): 832x624@75Hz
[    12.620] (II) AMDGPU(0): 1024x768@60Hz
[    12.620] (II) AMDGPU(0): 1024x768@75Hz
[    12.620] (II) AMDGPU(0): 1280x1024@75Hz
[    12.620] (II) AMDGPU(0): 1152x864@75Hz
[    12.620] (II) AMDGPU(0): Manufacturer's mask: 0
[    12.620] (II) AMDGPU(0): Supported standard timings:
[    12.620] (II) AMDGPU(0): #0: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[    12.620] (II) AMDGPU(0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    12.620] (II) AMDGPU(0): #2: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[    12.620] (II) AMDGPU(0): #3: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[    12.620] (II) AMDGPU(0): Supported detailed timing:
[    12.620] (II) AMDGPU(0): clock: 148.5 MHz   Image Size:  510 x 290 mm
[    12.620] (II) AMDGPU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[    12.620] (II) AMDGPU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    12.620] (II) AMDGPU(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 155 MHz
[    12.620] (II) AMDGPU(0): Monitor name: E2350
[    12.620] (II) AMDGPU(0): Serial No: 909NDPV2M319
[    12.620] (II) AMDGPU(0): EDID (in hex):
[    12.620] (II) AMDGPU(0): 	00ffffffffffff001e6d905701010101
[    12.620] (II) AMDGPU(0): 	0a14010380331d78eac665a059589d27
[    12.620] (II) AMDGPU(0): 	0e5054a76b80b30081808140714f0101
[    12.620] (II) AMDGPU(0): 	010101010101023a801871382d40582c
[    12.620] (II) AMDGPU(0): 	4500fe221100001e000000fd00384b1e
[    12.620] (II) AMDGPU(0): 	530f000a202020202020000000fc0045
[    12.620] (II) AMDGPU(0): 	323335300a20202020202020000000ff
[    12.620] (II) AMDGPU(0): 	003930394e445056324d3331390a00bb
[    12.620] (II) AMDGPU(0): Printing probed modes for output DVI-I-0
[    12.621] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    12.621] (II) AMDGPU(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    12.621] (II) AMDGPU(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    12.622] (II) AMDGPU(0): EDID for output DVI-D-1
[    12.622] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[    12.622] (II) AMDGPU(0): Output HDMI-A-0 connected
[    12.622] (II) AMDGPU(0): Output DVI-I-0 connected
[    12.622] (II) AMDGPU(0): Output DVI-D-1 disconnected
[    12.622] (II) AMDGPU(0): Using spanning desktop for initial modes
[    12.622] (II) AMDGPU(0): Output HDMI-A-0 using initial mode 1920x1080 +0+0
[    12.622] (II) AMDGPU(0): Output DVI-I-0 using initial mode 1920x1080 +1920+0
[    12.622] (II) AMDGPU(0): mem size init: gart size :f7657000 vram size: s:7f018000 visible:f018000
[    12.622] (==) AMDGPU(0): DPI set to (96, 96)
[    12.622] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[    12.622] (II) Loading sub module "ramdac"
[    12.622] (II) LoadModule: "ramdac"
[    12.622] (II) Module "ramdac" already built-in
[    12.622] (--) Depth 24 pixmap format is 32 bpp
[    12.622] (II) AMDGPU(0): [DRI2] Setup complete
[    12.622] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[    12.622] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[    12.622] (II) AMDGPU(0): Front buffer pitch: 15360 bytes
[    12.622] (II) AMDGPU(0): SYNC extension fences enabled
[    12.623] (II) AMDGPU(0): Present extension enabled
[    12.623] (**) AMDGPU(0): DRI3 enabled
[    12.623] (==) AMDGPU(0): Backing store enabled
[    12.623] (II) AMDGPU(0): Direct rendering enabled
[    12.923] (II) AMDGPU(0): Use GLAMOR acceleration.
[    12.923] (II) AMDGPU(0): Acceleration enabled
[    12.923] (==) AMDGPU(0): DPMS enabled
[    12.923] (==) AMDGPU(0): Silken mouse enabled
[    12.923] (II) AMDGPU(0): Set up textured video (glamor)
[    12.923] (II) AMDGPU(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    13.004] (--) RandR disabled
[    13.111] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    13.111] (II) AIGLX: enabled GLX_ARB_create_context
[    13.111] (II) AIGLX: enabled GLX_ARB_create_context_profile
[    13.111] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[    13.111] (II) AIGLX: enabled GLX_INTEL_swap_event
[    13.111] (II) AIGLX: enabled GLX_SGI_swap_control
[    13.111] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[    13.111] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[    13.111] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[    13.111] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[    13.111] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[    13.113] (II) AIGLX: Loaded and initialized radeonsi
[    13.113] (II) GLX: Initialized DRI2 GL provider for screen 0
[    13.215] (II) AMDGPU(0): Setting screen physical size to 1016 x 285
[    14.407] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[    14.407] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    14.407] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    14.407] (**) Power Button: Applying InputClass "system-keyboard"
[    14.407] (II) LoadModule: "libinput"
[    14.407] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    14.439] (II) Module libinput: vendor="X.Org Foundation"
[    14.439] 	compiled for 1.19.3, module version = 0.25.1
[    14.439] 	Module class: X.Org XInput Driver
[    14.439] 	ABI class: X.Org XInput driver, version 24.1
[    14.439] (II) Using input driver 'libinput' for 'Power Button'
[    14.439] (**) Power Button: always reports core events
[    14.439] (**) Option "Device" "/dev/input/event4"
[    14.439] (**) Option "_source" "server/udev"
[    14.439] (II) event4  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    14.439] (II) event4  - (II) Power Button: (II) device is a keyboard
[    14.439] (II) event4  - (II) Power Button: (II) device removed
[    14.453] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event4"
[    14.453] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    14.453] (**) Option "xkb_model" "pc105"
[    14.453] (**) Option "xkb_layout" "latam"
[    14.499] (II) event4  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    14.499] (II) event4  - (II) Power Button: (II) device is a keyboard
[    14.500] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    14.500] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    14.500] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    14.500] (**) Power Button: Applying InputClass "system-keyboard"
[    14.500] (II) Using input driver 'libinput' for 'Power Button'
[    14.500] (**) Power Button: always reports core events
[    14.500] (**) Option "Device" "/dev/input/event3"
[    14.500] (**) Option "_source" "server/udev"
[    14.500] (II) event3  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    14.500] (II) event3  - (II) Power Button: (II) device is a keyboard
[    14.500] (II) event3  - (II) Power Button: (II) device removed
[    14.516] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5/event3"
[    14.516] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    14.516] (**) Option "xkb_model" "pc105"
[    14.516] (**) Option "xkb_layout" "latam"
[    14.516] (II) event3  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    14.516] (II) event3  - (II) Power Button: (II) device is a keyboard
[    14.517] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event8)
[    14.517] (II) No input driver specified, ignoring this device.
[    14.517] (II) This device may have been added with another device file.
[    14.517] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event9)
[    14.517] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event10)
[    14.517] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event5)
[    14.517] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event6)
[    14.517] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event7)
[    14.518] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event0)
[    14.518] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[    14.518] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[    14.518] (II) Using input driver 'libinput' for 'USB Optical Mouse'
[    14.518] (**) USB Optical Mouse: always reports core events
[    14.518] (**) Option "Device" "/dev/input/event0"
[    14.518] (**) Option "_source" "server/udev"
[    14.573] (II) event0  - (II) USB Optical Mouse: (II) is tagged by udev as: Mouse
[    14.573] (II) event0  - (II) USB Optical Mouse: (II) device is a pointer
[    14.573] (II) event0  - (II) USB Optical Mouse: (II) device removed
[    14.613] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/0003:1BCF:0005.0001/input/input2/event0"
[    14.613] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 8)
[    14.613] (**) Option "AccelerationScheme" "none"
[    14.613] (**) USB Optical Mouse: (accel) selected scheme none/0
[    14.613] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[    14.613] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[    14.670] (II) event0  - (II) USB Optical Mouse: (II) is tagged by udev as: Mouse
[    14.670] (II) event0  - (II) USB Optical Mouse: (II) device is a pointer
[    14.670] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[    14.670] (II) No input driver specified, ignoring this device.
[    14.670] (II) This device may have been added with another device file.
[    14.670] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD (/dev/input/event1)
[    14.670] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "evdev keyboard catchall"
[    14.670] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput keyboard catchall"
[    14.670] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "system-keyboard"
[    14.670] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD'
[    14.670] (**) SINO WEALTH USB KEYBOARD: always reports core events
[    14.670] (**) Option "Device" "/dev/input/event1"
[    14.670] (**) Option "_source" "server/udev"
[    14.670] (II) event1  - (II) SINO WEALTH USB KEYBOARD: (II) is tagged by udev as: Keyboard
[    14.670] (II) event1  - (II) SINO WEALTH USB KEYBOARD: (II) device is a keyboard
[    14.670] (II) event1  - (II) SINO WEALTH USB KEYBOARD: (II) device removed
[    14.716] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0/0003:258A:0003.0002/input/input3/event1"
[    14.716] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD" (type: KEYBOARD, id 9)
[    14.716] (**) Option "xkb_model" "pc105"
[    14.716] (**) Option "xkb_layout" "latam"
[    14.718] (II) event1  - (II) SINO WEALTH USB KEYBOARD: (II) is tagged by udev as: Keyboard
[    14.718] (II) event1  - (II) SINO WEALTH USB KEYBOARD: (II) device is a keyboard
[    14.719] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD (/dev/input/event2)
[    14.719] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "evdev keyboard catchall"
[    14.719] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput keyboard catchall"
[    14.719] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "system-keyboard"
[    14.719] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD'
[    14.719] (**) SINO WEALTH USB KEYBOARD: always reports core events
[    14.719] (**) Option "Device" "/dev/input/event2"
[    14.719] (**) Option "_source" "server/udev"
[    14.720] (II) event2  - (II) SINO WEALTH USB KEYBOARD: (II) is tagged by udev as: Keyboard
[    14.720] (II) event2  - (II) SINO WEALTH USB KEYBOARD: (II) device is a keyboard
[    14.720] (II) event2  - (II) SINO WEALTH USB KEYBOARD: (II) device removed
[    14.770] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.1/0003:258A:0003.0003/input/input4/event2"
[    14.770] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD" (type: KEYBOARD, id 10)
[    14.770] (**) Option "xkb_model" "pc105"
[    14.770] (**) Option "xkb_layout" "latam"
[    14.771] (II) event2  - (II) SINO WEALTH USB KEYBOARD: (II) is tagged by udev as: Keyboard
[    14.771] (II) event2  - (II) SINO WEALTH USB KEYBOARD: (II) device is a keyboard
[    14.772] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event11)
[    14.772] (II) No input driver specified, ignoring this device.
[    14.772] (II) This device may have been added with another device file.
[    14.772] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[    14.773] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event13)
[    14.773] (II) No input driver specified, ignoring this device.
[    14.773] (II) This device may have been added with another device file.
[    14.773] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event14)
[    14.774] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event15)
[    14.774] (II) No input driver specified, ignoring this device.
[    14.774] (II) This device may have been added with another device file.
[    14.774] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event16)
[    14.775] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event17)
[    14.775] (II) No input driver specified, ignoring this device.
[    14.775] (II) This device may have been added with another device file.
[    14.776] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event18)
[    14.776] (II) No input driver specified, ignoring this device.
[    14.776] (II) This device may have been added with another device file.
[    14.776] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event19)
[    14.777] (II) config/udev: Adding input device PC Speaker (/dev/input/event20)
[    14.777] (II) No input driver specified, ignoring this device.
[    14.777] (II) This device may have been added with another device file.
[    14.777] (II) config/udev: Adding input device Xbox Gamepad (userspace driver) (/dev/input/event21)
[    14.777] (**) Xbox Gamepad (userspace driver): Applying InputClass "joystick catchall"
[    14.777] (II) LoadModule: "joystick"
[    14.787] (WW) Warning, couldn't open module joystick
[    14.787] (II) UnloadModule: "joystick"
[    14.787] (II) Unloading joystick
[    14.787] (EE) Failed to load module "joystick" (module does not exist, 0)
[    14.787] (EE) No input driver matching `joystick'
[    14.787] (II) Falling back to input driver `libinput'
[    14.787] (II) Using input driver 'libinput' for 'Xbox Gamepad (userspace driver)'
[    14.787] (**) Xbox Gamepad (userspace driver): always reports core events
[    14.787] (**) Option "Device" "/dev/input/event21"
[    14.787] (**) Option "_source" "server/udev"
[    14.788] (II) event21 - (II) Xbox Gamepad (userspace driver): (II) is tagged by udev as: Joystick
[    14.788] (II) event21 - (II) Xbox Gamepad (userspace driver): (II) device is a joystick, ignoring
[    14.830] (II) event21 - not using input device '/dev/input/event21'.
[    14.830] (EE) libinput: Xbox Gamepad (userspace driver): Failed to create a device for /dev/input/event21
[    14.830] (EE) PreInit returned 2 for "Xbox Gamepad (userspace driver)"
[    14.830] (II) UnloadModule: "libinput"
[    14.830] (II) config/udev: Adding input device Xbox Gamepad (userspace driver) (/dev/input/js0)
[    14.830] (II) No input driver specified, ignoring this device.
[    14.830] (II) This device may have been added with another device file.
[    14.831] (II) config/udev: Adding input device Xbox Gamepad (userspace driver) #2 (/dev/input/event22)
[    14.831] (**) Xbox Gamepad (userspace driver) #2: Applying InputClass "joystick catchall"
[    14.831] (II) LoadModule: "joystick"
[    14.831] (WW) Warning, couldn't open module joystick
[    14.831] (II) UnloadModule: "joystick"
[    14.831] (II) Unloading joystick
[    14.831] (EE) Failed to load module "joystick" (module does not exist, 0)
[    14.831] (EE) No input driver matching `joystick'
[    14.831] (II) Falling back to input driver `libinput'
[    14.831] (II) Using input driver 'libinput' for 'Xbox Gamepad (userspace driver) #2'
[    14.831] (**) Xbox Gamepad (userspace driver) #2: always reports core events
[    14.831] (**) Option "Device" "/dev/input/event22"
[    14.831] (**) Option "_source" "server/udev"
[    14.831] (II) event22 - (II) Xbox Gamepad (userspace driver) #2: (II) is tagged by udev as: Joystick
[    14.832] (II) event22 - (II) Xbox Gamepad (userspace driver) #2: (II) device is a joystick, ignoring
[    14.870] (II) event22 - not using input device '/dev/input/event22'.
[    14.870] (EE) libinput: Xbox Gamepad (userspace driver) #2: Failed to create a device for /dev/input/event22
[    14.870] (EE) PreInit returned 2 for "Xbox Gamepad (userspace driver) #2"
[    14.870] (II) UnloadModule: "libinput"
[    14.870] (II) config/udev: Adding input device Xbox Gamepad (userspace driver) #2 (/dev/input/js1)
[    14.870] (II) No input driver specified, ignoring this device.
[    14.870] (II) This device may have been added with another device file.
[    15.171] (II) AMDGPU(0): Allocate new frame buffer 1920x1080
[    15.171] (II) AMDGPU(0):  => pitch 7680 bytes
[    32.330] (--) AMDGPU(0): HDMI max TMDS frequency 150000KHz
[    32.361] (II) AMDGPU(0): EDID vendor "GSM", prod id 22416
[    32.361] (II) AMDGPU(0): Using EDID range info for horizontal sync
[    32.361] (II) AMDGPU(0): Using EDID range info for vertical refresh
[    32.361] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    32.361] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    32.361] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    32.361] (II) AMDGPU(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[    40.711] (--) AMDGPU(0): HDMI max TMDS frequency 150000KHz
[    40.742] (II) AMDGPU(0): EDID vendor "GSM", prod id 22416
[    40.742] (II) AMDGPU(0): Using hsync ranges from config file
[    40.742] (II) AMDGPU(0): Using vrefresh ranges from config file
[    40.742] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    40.742] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    40.742] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    40.742] (II) AMDGPU(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
Thanks for your help.
#843
Ist this with AMD staging kernel? You need to load this kernel to get the right config :joy:
#844
@Tids
But I can not load it, it stays in version version 232 and it does not go beyond that screen, it does not let me access control + f2 console mode, how else can I give you what you need ?. Thank you
#845
But since there is a xorg log it means that it was able to boot to xorg. Try to add 3 as bootoption in grub. That should let you boot without xorg startup.
#846
@Tids
I have tried with option 3 with the amd staging kernel and it stays the same, locked in starting version. I Try option 3 with kernel 4.9 and function 10 points, text mode with no problems. I try from a live cd using chroot, but when I do “uname -r” it tells me that it’s in the 4.9 kernel, I’m still searching the internet and trying to access it even if it’s by console. If you can think of a different way you can access it, I would appreciate it. Thank you
