amdgpu by NUC 8i7HVK (Radeon RX Vega M GH)
Hello,
but I noticed something during this test for this Threads:
If I run inxi -f and compare the output with an older posting of mine, does there seem to be something wrong with the amdgpu drivers?
In an older posting of mine you could see this:
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Vega [Radeon RX Vega M] bus-ID: 01:00.0 chip-ID: 1002:694c
           Display Server: x11 (X.Org 1.19.6 ) drivers: fbdev,ati (unloaded: modesetting,vesa,radeon)
           Resolution: 1920x1080@77.00hz
By Manjaro 18.0-beta5 i get this
Graphics:  Card-1: Advanced Micro Devices [AMD/ATI] Polaris 22 [Radeon RX Vega M GH] driver: amdgpu v: kernel
           Display: x11 server: X.Org 1.20.1 driver: amdgpu,ati unloaded: modesetting
           resolution: 2560x1440~60Hz
By Manjaro 18.0.0 Illyria
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Polaris 22 [Radeon RX Vega M GH] vendor: Intel driver: amdgpu v: kernel
           bus ID: 01:00.0 chip ID: 1002:694c
           Display: x11 server: X.Org 1.20.3 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
           compositor: kwin_x11 resolution: 2560x1440~60Hz
And by a new test with Manjaro 18.0.4 Illyria
i get this Message with amdgpu: failed
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Polaris 22 [Radeon RX Vega M GH] driver: amdgpu v: kernel
           Display: x11 server: X.Org 1.20.4 driver: amdgpu FAILED: ati unloaded: modesetting resolution: 2560x1440~60Hz
Does anyone have an idea or a plan what could be broken again?
But with Screenfetch, everything looks the same.
[egle@NUC8i7HVK ~]$ screenfetch
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     egle@NUC8i7HVK
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     OS: Manjaro 18.0.4 Illyria
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Kernel: x86_64 Linux 4.19.30-1-MANJARO
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Uptime: 51m
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ            β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Packages: 1323
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Shell: bash 5.0.0
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Resolution: 2560x1440
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     DE: KDE 5.56.0 / Plasma 5.15.3
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     WM: KWin
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     GTK Theme: Breath [GTK2/3]
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Icon Theme: maia
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     Font: Noto Sans Regular
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     CPU: Intel Core i7-8809G @ 8x 4.2GHz [54.0Β°C]
 β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ     GPU: AMD VEGAM (DRM 3.27.0, 4.19.30-1-MANJARO, LLVM 7.0.1)
                                  RAM: 3767MiB / 15991MiB
[egle@NUC8i7HVK ~]$
its not amdgpu: failed
its FAILED: ati
are you having any actual problems? i’ve seen this error at least once or twice in the past couple days
try a newer kernel like 5.0 and see if that and it’s modules play better together
sudo mhwd-kernel -i linux50
then select new kernel at grub selection menu under β€œadvanced options”
Nothing is broken. Perfectly normal output of inxi.
Hello @dglt,
Okay Thanks, "ati" is failed…
Hmm, actual i don’t have any problems.
Kernel 5 is not an option for me, had already tested it and it slows down my system every time it shuts down. I have to wait 2-3 minutes for some β€œwatchdog” until the computer shuts down.
With Kernel 4.19 my computer only needs 10-20 seconds to shut down
So Linux5.0 for me this is not an option…
@Signalrunner
Okay thank to read this :slight_smile:
