dmesg --level=emerg,alert,crit,err,warn
[ 0.005571] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20210105/tbfadt-615)
[ 0.272489] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 1.173064] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 12.526082] kauditd_printk_skb: 27 callbacks suppressed
[ 12.982214] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0x7d467000-0x7d467fff flags 0x200] vs 7d467000 4000
[ 12.982235] tpm_crb MSFT0101:00: can't request region for resource [mem 0x7d467000-0x7d467fff]
[ 12.982252] tpm_crb: probe of MSFT0101:00 failed with error -16
[ 13.512066] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 14.816237] ACPI Warning: \_SB.PCI0.GPP0.VGA._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210105/nsarguments-61)
[ 15.806655] kfd kfd: error getting iommu info. is the iommu enabled?
[ 15.806657] kfd kfd: Error initializing iommuv2
[ 15.807231] kfd kfd: device 1002:15dd NOT added due to errors
[ 16.275170] thermal thermal_zone1: failed to read out thermal zone (-61)
[ 26.310240] kauditd_printk_skb: 10 callbacks suppressed
[ 31.163760] ACPI: \: failed to evaluate _DSM (0x1001)
[ 31.163770] ACPI: \: failed to evaluate _DSM (0x1001)
[ 31.400319] ACPI: \: failed to evaluate _DSM (0x1001)
[ 31.400328] ACPI: \: failed to evaluate _DSM (0x1001)
[ 31.885841] kauditd_printk_skb: 11 callbacks suppressed
[ 37.144914] kauditd_printk_skb: 9 callbacks suppressed
[ 56.617685] kauditd_printk_skb: 9 callbacks suppressed
[ 61.693365] kauditd_printk_skb: 148 callbacks suppressed
[ 93.935038] kauditd_printk_skb: 11 callbacks suppressed
journalctl
Apr 25 11:23:13 Asus kernel: pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
Apr 25 11:23:13 Asus kernel: pci_bus 0000:02: resource 1 [mem 0xf7800000-0xf78fffff]
Apr 25 11:23:13 Asus kernel: pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
Apr 25 11:23:13 Asus kernel: pci_bus 0000:03: resource 1 [mem 0xf7700000-0xf77fffff]
Apr 25 11:23:13 Asus kernel: pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
Apr 25 11:23:13 Asus kernel: pci_bus 0000:04: resource 1 [mem 0xf7200000-0xf75fffff]
Apr 25 11:23:13 Asus kernel: pci_bus 0000:04: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref]
Apr 25 11:23:13 Asus kernel: pci_bus 0000:05: resource 1 [mem 0xf7600000-0xf76fffff]
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.1: D0 power state depends on 0000:04:00.0
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.3: extending delay after power-on from D3hot to 20 msec
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.4: extending delay after power-on from D3hot to 20 msec
Apr 25 11:23:13 Asus kernel: PCI: CLS 64 bytes, default 64
Apr 25 11:23:13 Asus kernel: Trying to unpack rootfs image as initramfs...
Apr 25 11:23:13 Asus kernel: Freeing initrd memory: 7332K
Apr 25 11:23:13 Asus kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
Apr 25 11:23:13 Asus kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Apr 25 11:23:13 Asus kernel: pci 0000:00:00.2: PCI INT A: not connected
Apr 25 11:23:13 Asus kernel: pci 0000:00:01.0: Adding to iommu group 0
Apr 25 11:23:13 Asus kernel: pci 0000:00:01.1: Adding to iommu group 1
Apr 25 11:23:13 Asus kernel: pci 0000:00:01.3: Adding to iommu group 2
Apr 25 11:23:13 Asus kernel: pci 0000:00:01.4: Adding to iommu group 3
Apr 25 11:23:13 Asus kernel: pci 0000:00:08.0: Adding to iommu group 4
Apr 25 11:23:13 Asus kernel: pci 0000:00:08.1: Adding to iommu group 5
Apr 25 11:23:13 Asus kernel: pci 0000:00:08.2: Adding to iommu group 4
Apr 25 11:23:13 Asus kernel: pci 0000:00:14.0: Adding to iommu group 6
Apr 25 11:23:13 Asus kernel: pci 0000:00:14.3: Adding to iommu group 6
Apr 25 11:23:13 Asus kernel: pci 0000:00:18.0: Adding to iommu group 7
Apr 25 11:23:13 Asus kernel: pci 0000:00:18.1: Adding to iommu group 7
Apr 25 11:23:13 Asus kernel: pci 0000:00:18.2: Adding to iommu group 7
Apr 25 11:23:13 Asus kernel: pci 0000:00:18.3: Adding to iommu group 7
Apr 25 11:23:13 Asus kernel: pci 0000:00:18.4: Adding to iommu group 7
Apr 25 11:23:13 Asus kernel: pci 0000:00:18.5: Adding to iommu group 7
Apr 25 11:23:13 Asus kernel: pci 0000:00:18.6: Adding to iommu group 7
Apr 25 11:23:13 Asus kernel: pci 0000:00:18.7: Adding to iommu group 7
Apr 25 11:23:13 Asus kernel: pci 0000:01:00.0: Adding to iommu group 8
Apr 25 11:23:13 Asus kernel: pci 0000:02:00.0: Adding to iommu group 9
Apr 25 11:23:13 Asus kernel: pci 0000:03:00.0: Adding to iommu group 10
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.0: Adding to iommu group 11
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.1: Adding to iommu group 12
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.2: Adding to iommu group 12
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.3: Adding to iommu group 12
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.4: Adding to iommu group 12
Apr 25 11:23:13 Asus kernel: pci 0000:04:00.6: Adding to iommu group 12
Apr 25 11:23:13 Asus kernel: pci 0000:05:00.0: Adding to iommu group 4
Apr 25 11:23:13 Asus kernel: pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
Apr 25 11:23:13 Asus kernel: pci 0000:00:00.2: AMD-Vi: Extended features (0x4f77ef22294ada):
Apr 25 11:23:13 Asus kernel: PPR NX GT IA GA PC GA_vAPIC
Apr 25 11:23:13 Asus kernel: AMD-Vi: Interrupt remapping enabled
Apr 25 11:23:13 Asus kernel: AMD-Vi: Virtual APIC enabled
Apr 25 11:23:13 Asus kernel: AMD-Vi: Lazy IO/TLB flushing enabled
Apr 25 11:23:13 Asus kernel: amd_uncore: AMD NB counters detected
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=70faa59c-ed2e-4e81-9777-f823a4e4050c ro
psmouse.synaptics_intertouch=0 quiet apparmor=1 security=apparmor
udev.log_priority=3 idle=nomwait sysrq_always_enabled=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X570ZD_F570ZD
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X570ZD v: 1.0 serial: <filter>
UEFI: American Megatrends v: X570ZD.312 date: 02/25/2020
ID-1: BAT0 charge: 27.7 Wh (65.8%) condition: 42.1/48.1 Wh (87.5%)
volts: 11.7 min: 11.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 217
RAM: total: 6.8 GiB used: 2.53 GiB (37.2%)
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 810100B cache: L2: 2 MiB bogomips: 31948
Speed: 1658 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz):
1: 1658 2: 1658 3: 1638 4: 1488 5: 1446 6: 1291 7: 1284 8: 1412
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 04:00.0 chip-ID: 1002:15dd
class-ID: 0300
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.2:4 chip-ID: 13d3:5a05 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.12.9-1-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f000
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 03:00.0
IF-ID-1: br-718e2cf9ece4 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: outline-tun0 state: down mac: N/A
IP v4: <filter> scope: global
bus-ID: 3-2.1:3 chip-ID: 8087:0a2b class-ID: e001
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 931.51 GiB used: 123.23 GiB (13.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
rotation: 5400 rpm serial: <filter> rev: 0J scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.6 GiB (98.32%)
used: 123.23 GiB (13.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 70faa59c-ed2e-4e81-9777-f823a4e4050c
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1EB2-5DFC
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 058f:6254 class-ID: 0900
Device-1: 3-2.1:3 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 3-2.2:4 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 54.8 C mobo: 54.0 C
Fan Speeds (RPM): cpu: 3100
GPU: device: amdgpu temp: 54.0 C device: nouveau temp: 46.0 C
Processes: 261 Uptime: 32m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1542 lib: 411
flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
