AMD turbocore for trinity proc
hello, there is an old laptop equipped with an AMD A10 4600M processor, in the window this processor has a turbo frequency of 3.2 ghz, due to which this old man still quite exports toys like Minecraft, but in Linux its frequency is locked at 2.3 ghz, while cpupower indicates that overclocking is possible but inactive, having tried everything that Google suggested. Exactly:
  1. changed the /sys/devices/system/cpu/cpufreq/boost file from 0 to 1
  2. Set the grub radeon startup parameter.bamp=1
    the result is 0, help with advice, then it is proposed to change the core, but in my heart I do not know how to do it, those guides that are written on the Internet are written by programmers for programmers, I do not understand half a word there, maybe someone has already solved this problem for themselves in a simpler way, or can write instructions for dummies here.
    analyzing CPU 3:
    driver: acpi-cpufreq
    CPUs which run at the same hardware frequency: 3
    CPUs which need to have their frequency coordinated by software: 3
    maximum transition latency: 4.0 us
    hardware limits: 1.40 GHz - 2.30 GHz
    available frequency steps: 2.30 GHz, 2.00 GHz, 1.80 GHz, 1.60 GHz, 1.40 GHz
    available cpufreq governors: conservative ondemand userspace powersave performance schedutil
    current policy: frequency should be within 1.40 GHz and 2.30 GHz.
    The governor “schedutil” may decide which speed to use
    within this range.
    current CPU frequency: 1.40 GHz (asserted by call to hardware)
    boost state support:
    Supported: yes
    Active: no
    Boost States: 2
    Total States: 8
    Pstate-Pb0: 3200MHz (boost state)
    Pstate-Pb1: 2700MHz (boost state)
    Pstate-P0: 2300MHz
    Pstate-P1: 2000MHz
    Pstate-P2: 1800MHz
    Pstate-P3: 1600MHz
    Pstate-P4: 1400MHz
KDE Plasma Version: 6.3.2
KDE Frameworks Version: 6.11.0
Qt Version: 6.8.2
Kernel Version: 6.12.17-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × AMD A10-4600M APU with Radeon™ HD Graphics
Memory: 14.8 ГиБ of RAM
Graphics Processor 1: AMD ARUBA
Graphics Processor 2: OLAND
Manufacturer: Hewlett-Packard
Product Name: HP ProBook 455 G1
System Version: A2018CD200
