AMD self panel refresh
Hello amd users!
I am searching people who have amd laptops and have tried the latest kernel( 5.5 Rc2)
Have you got better power usage in your laptops? do you know what is psr?
I have a HP laptop with a Ryzen 2500U and I've seen some gains with kernel 5.5 compared to 5.4 or 4.19. With 4.19 the battery life was at about 6 hours, with some applications open it was more like 5.5h, sometimes 5h. With kernels 5.1 - 5.4 that got a bit better by about half an hour.
If I have nothing open at all then the new battery life is about 7.5 hours. Once I use applications though (like Okular for example, just viewing some pdfs) then there doesn't seem to be much of a difference anymore. Using Firefox writing this results in about 5.5 hours, it changes a bit over time but should be about right (with WiFi on, so not bad at all, just not much at all compared to the improvements I've heard about with PSR)
Edit: now I actually charged the thing completely full (the numbers from before were calculated from the estimation for about 50%) and it looks like it's now more than 7 hours of actual usage, with WiFi on and multiple applications (Dolphin, Firefox & Okular) open.
can you tell me the output of cat /sys/kernel/debug/dri/0/state please?if you have more GPU's try with 0 and 1.
And can you give me the numbers of the power usage from powertop with linux 5.4 and 5.5 when idling? I am very curious of the power usage of your ryzen..
mine ryzen( asus fx505dy is so bad at powwer usage in linux.. more than 10 hours in windows and less than 4 in linux..
  1. to sum up in the PD, you are very happy with the new numbers beacuse your laptop is during more than before, no?
Finally someone who could tell me a way to check if PSR is actually active... It doesn't seem to be after all.
sudo cat /sys/kernel/debug/dri/0/state
plane[40]: plane-0
        crtc=(null)
        fb=0
        crtc-pos=0x0+0+0
        src-pos=0.000000x0.000000+0.000000+0.000000
        rotation=1
        normalized-zpos=0
        color-encoding=ITU-R BT.601 YCbCr
        color-range=YCbCr limited range
plane[43]: plane-1
        crtc=(null)
        fb=0
        crtc-pos=0x0+0+0
        rotation=1
        normalized-zpos=0
plane[46]: plane-2
        crtc=(null)
        fb=0
        crtc-pos=0x0+0+0
        rotation=1
        normalized-zpos=0
plane[49]: plane-3
        crtc=crtc-0
        fb=77
                allocated by = Xorg
                refcount=2
                format=XR24 little-endian (0x34325258)
                modifier=0x0
                size=1920x1080
                layers:
                        size[0]=1920x1080
                        pitch[0]=7680
                        offset[0]=0
                        obj[0]:
                                name=0
                                refcount=3
                                start=001079db
                                size=9109504
                                imported=no
        crtc-pos=1920x1080+0+0
        src-pos=1920.000000x1080.000000+0.000000+0.000000
        rotation=1
        normalized-zpos=0
plane[52]: plane-4
        crtc=(null)
        fb=0
        crtc-pos=0x0+0+0
        rotation=1
        normalized-zpos=0
plane[55]: plane-5
        crtc=(null)
        fb=0
        crtc-pos=0x0+0+0
        rotation=1
        normalized-zpos=0
plane[57]: plane-6
        crtc=(null)
        fb=0
        crtc-pos=0x0+0+0
        rotation=1
        normalized-zpos=0
plane[59]: plane-7
        crtc=(null)
        fb=0
        crtc-pos=0x0+0+0
        rotation=1
        normalized-zpos=0
plane[61]: plane-8
        crtc=(null)
        fb=0
        crtc-pos=0x0+0+0
        rotation=1
        normalized-zpos=0
crtc[56]: crtc-0
        enable=1
        active=1
        self_refresh_active=0
        planes_changed=1
        mode_changed=0
        active_changed=0
        connectors_changed=0
        color_mgmt_changed=0
        plane_mask=8
        connector_mask=1
        encoder_mask=1
        mode: "": 0 140240 1920 1968 2000 2124 1080 1083 1089 1100 0x0 0x9
crtc[58]: crtc-1
        enable=0
        active=0
        planes_changed=0
        mode_changed=0
        active_changed=0
        plane_mask=0
        connector_mask=0
        encoder_mask=0
        mode: "": 0 0 0 0 0 0 0 0 0 0 0x0 0x0
crtc[60]: crtc-2
        enable=0
        active=0
        planes_changed=0
        mode_changed=0
        active_changed=0
        plane_mask=0
        connector_mask=0
        encoder_mask=0
crtc[62]: crtc-3
        enable=0
        active=0
        planes_changed=0
        mode_changed=0
        active_changed=0
        plane_mask=0
        connector_mask=0
        encoder_mask=0
connector[64]: eDP-1
        crtc=crtc-0
        self_refresh_aware=0
connector[69]: HDMI-A-1
        crtc=(null)
connector[73]: DP-1
        crtc=(null)
I'm gonna give you some power values after my laptop's done updating (with kernel 5.5rc6 then) but I can say that I am rather satisfied with my battery life. It's not nearly the advertised 10 hours from HP but it's not like that on Windows either and it's enough for me 99% of the time.
It's 6.34W right now with pamac downloading udpates over WiFi and Firefox running, brightness at like 30% or so.
So a bit to my surprise (as despite there being no PSR I did have a battery life improvement with 5.5. Perhaps patches were backported) energy consumption in 5.4.11 and 5.5rc6 is the same, pretty much exactly 5W with WiFi disabled and screen brightness to minimum. It will be higher if you have a hard drive in your system (power usage on idle was like over 6W when I still had my HDD). Those 5W would result in a theoretical battery life of 8.5h in my case.
Btw, did you try disabling or resetting baloo / file search? If you have a lot of not indexed files and/or the file index is somehow corrupted then it will use all the battery it can.
I don't know if this is the way to check it after all, I have search so much and try so much to find it.. But it is nothing 100 percent secure because I have been investigating myself the files one by one
It can be enabled after all but not telling there bexcause it is not the place to see it.. The consumption fells to be good.. yeah.. for me the asus was giving very bad values.. I have returned it because I needed to have Linux not that way..
yeah, disabled baloo with kinfo center the last time, not any help, my laptop had a nvme drive of 512 GB and the Apst( If i remember well) enabled and working good ( I suppose..)
I couldn't bisect my problem of comsumption, I am thinking that the problem was the dGPU amd RX 560.. That is suppose to be disable when not in use, but I think is not true in all laptops, at least the 5.5Rc2 had a bug that the dGPU won't power off and the compsumption was almost the same.. so weird. 2 possibilities, 1, 5.5 had a big big improvement in battery terms that mitigate the compsumption of the dGPU( 6-7 W with no app running) or the GPU didn't get off never in linux.
Yeah I've heard that GPU switching was/is a rather big problem in X. It supposedly will be one of the things Wayland will improve on.
PSR is said to only have a power saving benefit of 0.5W roughly according to fedora developer blog post. If wattage can get pretty low while running that can make a difference, but if you're trying 10x that or more already, then the battery savings are perhaps less.
PSR also afaik only benefits when the display isn't updating any content at all, so basically when you're not doing anything and using the laptop, no running ksysguard with graph etc. I'm not sure how soon it triggers, so it's possible that it still might benefit if the screen isn't updating at a high frequency(some still frames)?
There's also PSR2, but I'm not sure if the upcoming PSR support for AMD covers that. PSR2 is improved version which will do the same for static content, but you can have some small parts of the screen update without affecting the rest of the screen(so the remainder of the display benefits from PSR), such as a blinking cursor or the time updating to the next minute.
/sys/kernel/debug/dri/0/eDP-1/psr_state
@Zamundaaa see this entry in the new 5.5 kernel
@kwhali my power usage is about 5 to 6W on idle, and thus it should give me at least half an hour to almost a whole hour of added battery life.
@agm28011997 Thanks!
It indeed seems to be off (cat on this file returns 0). Wonder why though.
I got my laptop which is Intel and while it's a cheap $400 USD model, it's a 2019Q3 model(10th gen Comet Lake U CPU).
It turned out it has a 2017 panel, I don't remember specifics on how to identify this information, I think you can get the model and manufacturer from dmi-decode or something like this..
Then I came across a website(panellook or something along those lines) that provides many details about a huge variety of panels, as well as where you can buy them from. It revealed that although it was a 2017 product, the panel still used eDP 1.2(2010) instead of eDP 1.3(2011) which is needed for PSR.
Thus it's possible that you just don't have eDP 1.3 or newer, more likely if your laptop is not a premium model I assume. In some cases, you can find a different panel that does have eDP 1.3 or newer, as long as it matches some specs that make it compatible with your laptops panel, it could be replaced afaik and it should work. I've thought about trying this, my panel costs around $50USD iirc, while the better panel that I was considering was 2-3x that, so it makes sense why for a product at the price I paid, made some cost cutting choices that most users wouldn't recognize to keep the price low..
I had heard of other users also stating that there wasn't any notable difference from the new kernel for their AMD systems too, and the above seems to explain why that is.
TL;DR: You need a display that supports eDP 1.3 or newer. Even new products from last year can be found with eDP 1.2 which was available since 2010.
