hi guys i using amd radeon r5 330m in my laptop i using manjaro from 2 days from that i searched about the graphic card drivers
but this no any thing about manjaro or arch
The AMD graphics drivers are already installed as they are included in the kernel. Newer GPUs will utilize the amdgpu
driver while older cards will use the legacy radeon
driver.
You can check by running the following command to only display your graphics info:
inxi -G
