AMD issue *atombios stuck in loop for 5 sec* SOLUTION
Continuing the discussion from [SOLVED] AMD issuse on Boot Again and again :tired_face::
i also had the same problem for months now. According to this bug report in the comment section
https://bugs.freedesktop.org/show_bug.cgi?id=103783 you should deinstall the tlp package, which
solved my problem.
pacman -Rs tlp
Greetings
A better solution would be this:
which I can add to Manjaro’s TLP package overlay, and which may fix the issue for more people.
