Everything was working fine until I updated to latest.
Now whenever I try to output the “greater than” or “less than” symbols with: AltGr + LeftShift + Z (or X) I get these symbols: “‹ ›”
I before the update that key combination would give: “< >”
Help! Any tips on how to revert this change? :’(
Solution:
Output current key map table:
xmodmap -pke > ~/.Xmodmap
Edit it and look for the lines:
keycode 52 = z Z z Z guillemotleft U2039 guillemotleft
keycode 53 = x X x X guillemotright U203A guillemotright
Replace U2039 with less, and replace U203A with greater:
keycode 52 = z Z z Z guillemotleft less guillemotleft
keycode 53 = x X x X guillemotright greater guillemotright
Test the changes:
xmodmap ~/.Xmodmap
That’s it!
