i just operate manjaro in my old dell laptop with xfce after kde keep freeze in log in screen but in xfce the keyboard keys not working well like kde was fine , i keep changing the keyboard layout but in every change there keys not working or swapping places,
here my device info:
Host: osamaxfce Kernel: 5.15.53-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.1.0 Desktop: Xfce v: 4.16.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: Latitude E5440 v: 00
serial: <superuser required>
Mobo: Dell model: 0XFRKC v: A01 serial: <superuser required> BIOS: Dell
v: A23 date: 10/08/2018
ID-1: BAT0 charge: 50.9 Wh (67.8%) condition: 75.1/99.9 Wh (75.1%)
volts: 11.7 min: 11.1 model: SMP DELL 45HHN33 status: discharging
Info: dual core model: Intel Core i3-4030U bits: 64 type: MT MCP
arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1721 high: 1896 min/max: 800/1900 cores: 1: 1196
2: 1896 3: 1896 4: 1896 bogomips: 15168
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen7.5 bus-ID: 00:02.0
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.6:3
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
gpu: i915 resolution: 1366x768~60Hz
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.15.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.54 running: yes
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0
IF: eno1 state: down mac: 34:e6:d7:35:ea:e6
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 02:00.0
IF: wlp2s0 state: up mac: d8:fc:93:52:32:71
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 bus-ID: 00:1f.2
Local Storage: total: 119.24 GiB used: 25.81 GiB (21.6%)
ID-1: /dev/sda model: SSD 128GB size: 119.24 GiB
ID-1: / size: 48.91 GiB used: 25.81 GiB (52.8%) fs: ext4 dev: /dev/sda3
System Temperatures: cpu: 40.0 C mobo: 35.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3017
Processes: 202 Uptime: 46m Memory: 7.67 GiB used: 2.18 GiB (28.4%)
Init: systemd Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1204
Shell: Bash v: 5.1.16 inxi: 3.3.19
