After installing a custom .XCompose
[1], the Alt + K
key-combination doesn’t work anymore, while all other Alt
combinations work. I can see which ones work in Configuration → Input devices → Keyboard → Layouts
and clicking on Preview
after choosing a layout.
If I remove the .XCompose
or switch to Wayland, it works again, but not under X11. Besides, there isn’t any composition in the .XCompose
involving the Alt
key as far as I know, which is odd that it breaks the shortcut.
Where might this issue come from? Would it be possible to somehow have both the .XCompose
and the key-combination work?
Thanks for your time!
EDIT: it’s Alt + K
on my keyboard layout, but really it seems to be the specific key on the keyboard rather than the character assigned to it. If I change my layout to QWERTY, the combination not working is Alt + B
[1] https://raw.githubusercontent.com/andrewathalye/bepo-xcompose-fix/main/XCompose
