Already up to date warning despite being updated in the arch repository
Hi I’m trying to update Telegram to the latest version but after doing
sudo pacman -Syu
everything is up to date but Telegram had a recent release
specifically it was intalled from extra.
Is there some other command I need to use in order to update?
(last version telegram-desktop 4.11.1-1 in extra, I’m stuck in 4.10.3-1 )
So what if it had recent release? If it’s not in branch you’re using, then you can’t update it from there.
https://packages.manjaro.org/?query=telegram
If you needed it urgently you could either change to unstable branch and update or install telegram-desktop-bin from AUR until it reaches the other branches.
thank you I did not knew about the branches aproach in Manjaro. Instructed myself from here:
