cat /etc/default/grub ✔
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3 mem_sleep_default=deep"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
~ cat /sys/power/mem_sleep ✔
[s2idle] deep
It almost looks like the initramfs wasn’t replaced. Or something. Please post the output of:
sudo mkinitcpio -P
Ok, here
==> Building image from preset: /etc/mkinitcpio.d/linux65.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.5-x86_64 -g /boot/initramfs-6.5-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.5.13-7-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.5-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux65.preset: 'fallback'
-> -k /boot/vmlinuz-6.5-x86_64 -g /boot/initramfs-6.5-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.5-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.6.10-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
Firstly, you should remove that kernel, since it’s been EOL since November 2023 already:
sudo mhwd-kernel --remove linux65
The old and unsupported kernel also suggests you haven’t updated recently. Which means you’ve been a bad, naughty boy.
Then, I just clicked, the mkinitcpio commands were unecessary. What you need to do now, is reinstall grub. This can be done with:
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Although, note: There might still be something missing, or wrong since it is mostly an educated guess as well. More can be found here:
If you get an error during the reinstallation mentioned above, provide the output of the command along with:
sudo lsblk -f
If you don’t have an error, reboot and check again.
Thanks a lot, the manjaros were inside a ventoy flash from summer 2023, that’s why the kernel was so ol, although I’ve changed to the last LTS one. But after remove the old one and updating the grub, everything works fine.
You’re the best.
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
Note for you both.
When you augment boot options like at /etc/default/grub
then you must follow it up with updating grub with those options.
sudo update-grub
The above script used to be included by default. It is about equivalent to
sudo grub-mkconfig -o /boot/grub/grub.cfg
Neglecting to do this is why it didnt stick.
(and eventually running grub-install is why it accidentally did, but this is overpowered for simply applying an option)
This should similarly be run after rebuilding initial ramdisk (mkinitcpio), but is notably different than it.
PS.
A similar thing can be said about grub-install
, but I would like to point out also the new script and pacman hook install-grub
Once installed you can use it to reinstall (upgrade) the bootloader.
(instead of the long grub-install
string above)
sudo pacman -Syu install-grub
sudo install-grub
But it also contains a hook that should do this for you whenever package changes make it necessary.
Cheers.
Thank you!
