I’ve installed recently Almond from FlatPak but my KDE desktop doesn’t launch It (other programs from FlatPak recently installed It does…).
I’ll apreciate any insight or experience…
Thanks
HI @ivappanther,
is the file set as excuteable? To do so, run:
chmod +x </path/to/file>
In the terminal. Where </path/to/file>
is, you guessed it, the path to the file.
Hope this helps!
What is the output of the following command?
flatpak run edu.stanford.Almond
(edu.stanford.Almond:2): Gjs-CRITICAL **: 18:35:58.238: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process edu.stanford.Almond.BackgroundService exited with status 1
spawnServiceDBusActivation@resource:///edu/stanford/Almond/js/app/servicelaunch.js:60:13
spawnService@resource:///edu/stanford/Almond/js/app/servicelaunch.js:86:9
main@resource:///edu/stanford/Almond/js/app/main.js:127:21
run@resource:///org/gnome/gjs/modules/script/package.js:222:19
@/app/bin/edu.stanford.Almond:6:17
(edu.stanford.Almond:2): Gjs-CRITICAL **: 18:35:58.238: Script /app/bin/edu.stanford.Almond threw an exception
Somebody knows what’s happening with this response to that command ?
I’ve researched something about what’s dbus in Linux like Desktop sistems, perhaps given the nature of Almond as virtual assistant it’s a problem related to KDE…
Any insight ?
Thanks …
The last update was from August 2021 and their GitHub issues are mentioning outdated dependencies. There is not much you can do on your side.
Ok thanks a lot!! Hope it’ll resolved finally.
