Hello i bought a lenovo ideapad slim 3 laptop and installed manjaro kde on it. But my question is that most of the keyboard key is not working as expected. What should i do ?
my system info
KDE Plasma Version: 5.22.4
KDE Frameworks Version: 5.85.0
Qt Version: 5.15.2
Kernel Version: 5.10.60-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 2 × Intel® Pentium® CPU G4400 @ 3.30GHz
Memory: ১৫.৬ GiB of RAM
Graphics Processor: GeForce GT 1030/PCIe/SSE2
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
