I have manjaro on several computers. On one computer only, any kernel later than 5.4.78-1 will work for 10-15 minutes and then freeze. Does anyone have any idea what the issue could be?
inxi --admin --verbosity=7 --filter --no-host
> System:
> Kernel: 5.4.78-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64
> root=UUID=058f6066-00b5-43d6-bf9c-3f98b86ae805 rw quiet apparmor=1
> security=apparmor udev.log_priority=3
> Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
> dm: LightDM 1.30.0 Distro: Manjaro Linux
> Machine:
> Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx serial: <filter>
> BIOS: American Megatrends v: 2603 date: 06/26/2015
> Memory:
> RAM: total: 15.54 GiB used: 1.65 GiB (10.6%)
> RAM Report:
> permissions: Unable to run dmidecode. Root privileges required.
> CPU:
> Info: 6-Core model: AMD FX-6300 bits: 64 type: MCP arch: Bulldozer
> family: 15 (21) model-id: 2 stepping: N/A microcode: 6000852
> L2 cache: 2048 KiB bogomips: 42159
> Speed: 1404 MHz min/max: 1400/3500 MHz boost: enabled Core speeds (MHz):
> 1: 1439 2: 1599 3: 1403 4: 1400 5: 1401 6: 1404
> Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
> cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
> extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
> hw_pstate ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor
> msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
> pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
> popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
> sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
> vme vmmcall wdt xop xsave
> Vulnerabilities: Type: itlb_multihit status: Not affected
> Type: l1tf status: Not affected
> Type: mds status: Not affected
> Type: meltdown status: Not affected
> Type: spec_store_bypass
> mitigation: Speculative Store Bypass disabled via prctl and seccomp
> Type: spectre_v1
> mitigation: usercopy/swapgs barriers and __user pointer sanitization
> Type: spectre_v2
> mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
> Type: srbds status: Not affected
> Type: tsx_async_abort status: Not affected
> Graphics:
> Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga
> driver: nouveau v: kernel bus ID: 07:00.0 chip ID: 10de:1c02
> Display: x11 server: XOrg 1.20.9 driver: nouveau unloaded: modesetting
> alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
> Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2")
> s-diag: 582mm (22.9")
> Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 82
> size: 598x336mm (23.5x13.2") diag: 686mm (27")
> OpenGL: renderer: NV136 v: 4.3 Mesa 20.2.2 direct render: Yes
> Audio:
> Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
> bus ID: 00:14.2 chip ID: 1002:4383
> Device-2: Creative Labs EMU20k2 [Sound Blaster X-Fi Titanium Series]
> driver: snd_ctxfi v: kernel bus ID: 05:00.0 chip ID: 1102:000b
> Device-3: NVIDIA GP106 High Definition Audio vendor: eVga
> driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 10de:10f1
> Device-4: Texas Instruments PCM2902 Audio Codec type: USB
> driver: hid-generic,snd-usb-audio,usbhid bus ID: 8-2:2 chip ID: 08bb:2902
> Sound Server: ALSA v: k5.4.78-1-MANJARO
> Network:
> Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
> vendor: ASUSTeK P8 series driver: r8169 v: kernel port: e000
> bus ID: 02:00.0 chip ID: 10ec:8168
> IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
> IP v4: <filter> type: dynamic noprefixroute scope: global
> broadcast: <filter>
> IP v6: <filter> type: noprefixroute scope: link
> WAN IP: <filter>
> Drives:
> Local Storage: total: 1.36 TiB used: 968.92 GiB (69.8%)
> SMART Message: Required tool smartctl not installed. Check --recommends
> ID-1: /dev/sda vendor: Kingston model: SV300S37A120G size: 111.79 GiB
> block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
> serial: <filter> rev: BBF0 scheme: MBR
> ID-2: /dev/sdb vendor: Seagate model: ST3250310AS size: 232.83 GiB
> block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
> serial: <filter> rev: A scheme: MBR
> ID-3: /dev/sdc vendor: Hitachi model: HDS721010DLE630 size: 931.51 GiB
> block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
> rotation: 7200 rpm serial: <filter> rev: A5R0 scheme: MBR
> ID-4: /dev/sdd vendor: Intel model: SSDSC2MH120A2 size: 111.79 GiB
> serial: <filter> rev: PPG4 scheme: MBR
> Message: No Optical or Floppy data was found.
> RAID:
> Message: No RAID data was found.
> Partition:
> ID-1: / raw size: 111.79 GiB size: 109.53 GiB (97.98%)
> used: 97.02 GiB (88.6%) fs: ext4 dev: /dev/sdd1 label: N/A
> uuid: 058f6066-00b5-43d6-bf9c-3f98b86ae805
> ID-2: /run/media/e/Hitachi raw size: 931.51 GiB size: 931.51 GiB (100.00%)
> used: 871.89 GiB (93.6%) fs: ntfs dev: /dev/sdc1 label: Hitachi
> uuid: 5CF071DFF071C036
> Swap:
> Alert: No Swap data was found.
> Unmounted:
> ID-1: /dev/sda1 size: 100.0 MiB fs: ntfs label: System Reserved
> uuid: 081896011895EDC6
> ID-2: /dev/sda2 size: 111.18 GiB fs: ntfs label: N/A
> uuid: 5C6899A468997D88
> ID-3: /dev/sda3 size: 519.0 MiB fs: ntfs label: N/A uuid: FAF479A9F4796931
> ID-4: /dev/sdb1 size: 156.25 GiB fs: ext4 label: N/A
> uuid: 4f327826-173b-4177-949f-d218ef43be45
> ID-5: /dev/sdb2 size: 76.58 GiB fs: crypto_luks label: N/A
> uuid: e398e87c-1a17-4594-b0f8-7c1d58263d42
> USB:
> Hub: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
> speed: 480 Mb/s chip ID: 1d6b:0002
> Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
> Device-1: 2-1:2 info: Alcor Micro AU6477 Card Reader Controller
> type: Mass Storage,HID driver: hid-generic,usb-storage,usbhid
> interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 058f:6364 serial: <filter>
> Hub: 3-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
> Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
> chip ID: 1d6b:0003
> Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
> Hub: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
> Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
> chip ID: 1d6b:0003
> Hub: 8-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
> chip ID: 1d6b:0001
> Device-1: 8-2:2 info: Texas Instruments PCM2902 Audio Codec
> type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
> rev: 1.1 speed: 12 Mb/s chip ID: 08bb:2902
> Device-2: 8-3:3 info: Dell Keyboard SK-8115 type: Keyboard
> driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
> chip ID: 413c:2003
> Device-3: 8-4:4 info: Logitech M105 Optical Mouse type: Mouse
> driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
> chip ID: 046d:c077
> Hub: 9-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
> chip ID: 1d6b:0001
> Hub: 10-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
> speed: 12 Mb/s chip ID: 1d6b:0001
> Hub: 11-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1
> Sensors:
> System Temperatures: cpu: 26.0 C mobo: N/A gpu: nouveau temp: 52.0 C
> Fan Speeds (RPM): N/A gpu: nouveau fan: 0
> Info:
> Processes: 212 Uptime: 34m Init: systemd v: 246 Compilers: gcc: 10.2.0
> clang: 11.0.0 Packages: 1637 pacman: 1633 lib: 435 flatpak: 0 snap: 4
> Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
