So i just wanted to make some aliasPack called “Spaceman” but aliases dont rly work on another session of terminal, it’s like i use command alias but it would not work when i restart terminal or just add another tab to it ;((
You need to put aliases into ~/.bashrc to have them be persistant across sessions.
Umm, ok but how do i do it?
Like so.
alias np='nano -w PKGBUILD'
alias more=less
but im doing it like this, like u just say i should
Open up the .bashrc
file, which is located in your /home/$USER/ folder. It’s hidden.
Then add the alias line to it at the bottom.
like this?
s="sudo"
spaceman="s pacman"
install="-S"
remove="-Ryuu"
(Thats my whole file)
Edit: It still dont works
Your example would be:
alias s="sudo"
alias spaceman="s pacman"
alias install="-S"
alias remove="-Ryuu"
You should do source ~/.bashrc
to test it without relogging.
But, I am not sure it would work if you do spaceman install <package>
, since it has 2 aliases in the same command. Never tried that.
After typing source ~/.bashsrc
in terminal i got this:
/home/cartoonguy/.bashrc:type:64: bad option: -P
zsh: command not found: complete
zsh: command not found: shopt
Ah, you are running ZSH. That’s a pretty important information there, since that has nothing to do with .bashrc…
See:
should i restart my pc?
No, just log out and log back in, or run…
source ~/.zshrc
