Just the gif on the github page got me laughing out loud
Haha yeah I could! I’ve seen it before but never bothered.
My alias is more polite though
Hi, I had thought of opening such a topic as well =)
I personally use fish and there is no fishrc, instead there is a config file hidden somewhere in the dot-directories, so I made a fishrc via a symbolic link which sources 2 files : 1 for aliases and 1 for functions, here they are :
.alias
##### alias commands for fish ##########
##### unixversal commands ###################
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF'
alias c='clear'
alias cc='cd && clear'
alias cl='clear ; l'
alias ko='killall'
alias md='mkdir'
alias tatiana-silva='curl wttr.in'
alias e='exit'
alias r='rm -rf'
alias s='sudo'
alias hip='hostname -i'
alias sa='source ~/.fishrc'
##### installed programs ##############
alias p='bpython'
alias eog='eog >/dev/null 2>&1'
alias nf='echo \n ; neofetch'
alias tget='torsocks wget' # wget via tor
alias tb='tensorboard --logdir logs'
#alias darknet='~/Documents/darknet/darknet'
alias yt='youtube-dl'
alias nn='netron'
alias dk="docker"
alias dkc="docker-compose"
######## personal programs ##########
alias sc='cat ~/.tg/raccourcis_clavier' ### prints keyboard shortcuts
alias sz='~/.tg/szz' ### prints files sizes
alias imsz='p ~/.tg/im.py' ### prints an image's size
alias rmdl='rm ~/.cache/torch/checkpoints/*' ### deletes downloaded pytorch models
alias onnx='p ~/.tg/ox.py' #### deep learning model conversion to/from onnx
####### terminal color (for KONSOLE only) #########
alias aoi='qdbus $KONSOLE_DBUS_SERVICE $KONSOLE_DBUS_WINDOW newSession aoi $PWD >/dev/null' # bleu
alias kawaii='qdbus $KONSOLE_DBUS_SERVICE $KONSOLE_DBUS_WINDOW newSession kawaii $PWD >/dev/null' # rose
alias midori='qdbus $KONSOLE_DBUS_SERVICE $KONSOLE_DBUS_WINDOW newSession midori $PWD >/dev/null' # vert
alias akai='qdbus $KONSOLE_DBUS_SERVICE $KONSOLE_DBUS_WINDOW newSession akai $PWD >/dev/null' #rouge
alias orenji='qdbus $KONSOLE_DBUS_SERVICE $KONSOLE_DBUS_WINDOW newSession orenji $PWD >/dev/null' #orange
alias kiiroi='qdbus $KONSOLE_DBUS_SERVICE $KONSOLE_DBUS_WINDOW newSession kiiroi $PWD >/dev/null' #jaune
alias kuro='qdbus $KONSOLE_DBUS_SERVICE $KONSOLE_DBUS_WINDOW newSession kuro $PWD >/dev/null' #noir
######## pacman ##########
alias pacmaj='sudo pacman -Syyu ; sudo paccache -rvk2'
alias paco='pacman -Qdtq | sudo pacman -Rs -'
.functions :
######### fish functions ##########
function g
printf \n
grep $argv
printf \n
end
function ddrive
wget "https://drive.google.com/uc?export=download&id=$argv[1]" --output-document="$argv[2]"
end
function a
atom $argv &
end
function v
vlc $argv > /dev/null 2>&1 &
end
function m
argparse "p/play" -- $argv
if set -q _flag_play
mpv --playlist=$argv > /dev/null 2>&1 &
else
mpv $argv > /dev/null 2>&1 &
end
end
function liz
elisa $argv >/dev/null 2>&1 &
end
function psp
PPSSPPQt $argv >/dev/null 2>&1 &
end
function ds
desmume $argv >/dev/null 2>&1 &
end
function pdf
okular $argv >/dev/null 2>&1 &
end
function jap
printf \n
grep $argv ~/Documents/japonais/adjectifs ; grep $argv ~/Documents/japonais/verbes ; grep $argv ~/Documents/japonais/voc
printf \n
end
function sd
sed "s/$argv[1]/$argv[2]/g" $argv[3]
end
function sdk
if ps -e | grep -q dockerd
echo shutting docker...
sudo systemctl stop docker
echo docker OFF !!!\n
else
echo starting docker...
sudo systemctl start docker
echo docker ON !!!\n
end
end
function cmdk #### prints docker commands
set l (count $argv)
if test $l -eq 0
echo \n
cat ~/.tg/dkcmd
else
g $argv ~/.tg/dkcmd
end
end
Can I translate your comments to english ? just so people can just copy and paste ?
I don’t use aliases. I prefer to remember the commands and parameters.
If the execution is complex I prefer to build a script in bash.
But in my git repository I have found a funny alias. Surely it is copied from another user
#Like matrix console display
alias matrix='echo -e "\e[32m"; while :; do for i in {1..16}; do r="$(($RANDOM % 2))"; if [[ $(($RANDOM % 5)) == 1 ]]; then if [[ $(($RANDOM % 4)) == 1 ]]; then v+="\e[1m $r "; else v+="\e[2m $r "; fi; else v+=" "; fi; done; echo -e "$v"; v=""; done'
I directly edited them
Thanks you anyway for translating them
You can use the program without creating an account, but the browser extension requires it.
He asked me via terminal. I think it would be better to do it at this point.
Do what?
Do an account for make the test with the terminal.
Love the ‘tatiana-silva’ alias, i use the same command (‘curl wttr.in’) but my alias is ‘météo’ …
