ALC294 Analog - Audio card detected, but no sound internaly or headphones
#21
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC294 Analog [ALC294 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
$ hwinfo --sound
16: PCI 1f.3: 0403 Audio device
  [Created at pci.378]
  Unique ID: nS1_.rmrmbBpgsVF
  SysFS ID: /devices/pci0000:00/0000:00:1f.3
  SysFS BusID: 0000:00:1f.3
  Hardware Class: sound
  Model: "Intel Audio device"
  Vendor: pci 0x8086 "Intel Corporation"
  Device: pci 0x9dc8
  SubVendor: pci 0x1043 "ASUSTeK Computer Inc."
  SubDevice: pci 0x16ce
  Revision: 0x30
  Driver: "snd_hda_intel"
  Driver Modules: "snd_hda_intel"
  Memory Range: 0xb1218000-0xb121bfff (rw,non-prefetchable)
  Memory Range: 0xb1000000-0xb10fffff (rw,non-prefetchable)
  IRQ: 128 (1028 events)
  Module Alias: "pci:v00008086d00009DC8sv00001043sd000016CEbc04sc03i80"
  Driver Info #0:
    Driver Status: snd_hda_intel is active
    Driver Activation Cmd: "modprobe snd_hda_intel"
  Driver Info #1:
    Driver Status: snd_soc_skl is active
    Driver Activation Cmd: "modprobe snd_soc_skl"
  Config Status: cfg=new, avail=yes, need=no, active=unknown
Just got a brand new asus zenbook and installed ubuntu, still no audio. I wiped windows, as I don’t use it.
#22
Please start new topic and post system information from inxi -Fxxz
“Subdevices: 1/1” suggests no connection from Pulseaudio
would expect it to show 0/1
check Pulseaudio settings for audio device:
pactl list sinks
or install pavucontrol or pasystray
#23
Hi,
ALC294 works but you will have to recompile the kernel :confused:
A patched was made that you can find at
http://mailman.alsa-project.org/pipermail/alsa-devel/2018-December/142689.html
Be carefull there are 3 mails containing differents patches of the same file sound/pci/hda/patch_realtek.c
Personnally I have a ASUS UX433 laptop and I applied this patch on the linux-4.19.8.tar.xz kernel with a Debian distro.
Once done all works ok.
It should works also on a ASUS UX533.
Hope this helps.
Mohamed.
#24
Simply move to testing/unstable branch updates and install kernel 4.19 series :stuck_out_tongue_winking_eye: Manjaro is SIMPLE. :wink:
If any:
sudo mhwd-kernel -i linux419
#25
4.19 kernel is on stable branch, so should not need to change to testing/unstable
@mohamed-badaoui would you be able to post audio information from patched Debian system from alsa-info or HDA Analyzer here?
would be very helpful to know working pin connections,
may be possible to apply it in HDAjackretask to get sound working
#26
Patches for ASUS sound issues was applied in 4.19.8-2 release via this commit >
Naming taken from this:
#27
was kernel v4.17 when this topic started
hope update gets moved through to stable soon, may help some other topics on laptop codecs too
#28
I’ve update my kernel to v19.9 but still the sound is not working :frowning:
#29
Paste results from app hwinfo (install if needed via pacman):
hwinfo --sound
@philm each one of ASUS new laptop models with Realtek ALC294 have individual hwinfo SubVendor and SubDevice values. They are needed for QUIRK hack directly in /sound/pci/hda/patch_realtek.c file.
For example (based on LP post some guy):
I have made it working for UX391UA laptop. I am using Linux Mint 19.
What I did:
  1. Follow this on how to download and compile linux kernel from sources (I use 4.19.9)
  2. check compiled kernel (reboot)
  3. Apply 3 patches from here:
    3.1 https://lkml.org/lkml/2018/12/7/158
    3.2 https://lkml.org/lkml/2018/12/7/160
    3.3 https://lkml.org/lkml/2018/12/7/159
  4. Additionally specify my laptop in same file by adding one more change:
SND_PCI_QUIRK(0x1043, 0x14a1, "ASUS UX533FD", ALC294_FIXUP_ASUS_SPK),
+SND_PCI_QUIRK(0x1043, 0x10a1, "ASUS UX391UA", ALC294_FIXUP_ASUS_SPK),
  1. Recompile kernel and reboot
  2. Now I have sound!
Values HEX of hwinfo SubVendor and SubDevice values are taken from hwinfo --sound
VBlack (vblack2006) wrote 4 hours ago: #64
I take my numbers from
hwinfo --sound
(SubVendor and SubDevice)
13: PCI 1f.3: 0403 Audio device
Unique ID: nS1_.CMWMjFG1cGE
Model: “Intel Audio device”
Vendor: pci 0x8086 “Intel Corporation”
Device: pci 0x9d71
SubDevice: pci 0x10a1
Revision: 0x21
Driver: “snd_hda_intel”
Driver Modules: “snd_hda_intel”
Memory Range: 0xec228000-0xec22bfff (rw,non-prefetchable)
Memory Range: 0xec200000-0xec20ffff (rw,non-prefetchable)
IRQ: 125 (338 events)
Module Alias: “pci:v00008086d00009D71sv00001043sd000010A1bc04sc03i80”
Driver Info #0:
Driver Activation Cmd: “modprobe snd_hda_intel”
Driver Info #1:
Driver Activation Cmd: “modprobe snd_soc_skl”
So, patch wil be:
+SND_PCI_QUIRK(0x1043, 0x10a1, “ASUS UX391UA”, ALC294_FIXUP_ASUS_SPK).
I must boot from lastest Manjaro ISO USB and checkout my values (R542UF)
EDIT
I booted manjaro-kde-18.0-stable-x86_64.iso aaaand sounds works (internal speakers) like a charm.
Sound details:
[manjaro@manjaro ~]$ sudo hwinfo --sound
20: PCI 1f.3: 0403 Audio device
  Unique ID: nS1_.b28td23g3aB
  Device: pci 0x9d71
  SubDevice: pci 0x1a00
  Revision: 0x21
  Memory Range: 0xef528000-0xef52bfff (rw,non-prefetchable)
  Memory Range: 0xef500000-0xef50ffff (rw,non-prefetchable)
  IRQ: 130 (615 events)
  Module Alias: "pci:v00008086d00009D71sv00001043sd00001A00bc04sc03i00"
  Driver Info #0:
  Driver Info #1:
[RESOLVED in 4.19.10] Realtek ALC294 @ Intel Sunrise Point-LP PCH - No sound (speakers and headphones)
#30
@FadeMind you have patched kernel source and recompiled the kernel or do it in another way?
The mentioned patch i see already imported into the kernel 4.20 (master branch)
#31
I downloaded lastest stable ISO KDE and boot in Live Non Free Mode.
#32
I see a solution marked here now, but is it actually correct for the OP?
(appears not to have visited here for months)
Or is this from one of the 2 recent new users yet to post their own request?
If it is the latter, please remove the solution tick mark that may not relate to original problem and summary might mislead others that may come across this in future
#33
THIS is solution, quirk marks for each Realtek Chip (see descr.) In upcomming 4.19.10 these patches are merged in master https://lkml.org/lkml/2018/12/14/721
Jian-Hong Pan <jian-hong@endlessm.com>
    ALSA: hda/realtek: Enable audio jacks of ASUS UX433FN/UX333FA with ALC294
    ALSA: hda/realtek: Enable audio jacks of ASUS UX533FD with ALC294
BUT for some variants of ASUS notebooks is required CUSTOM quirk IDs, cause it is not included in official patchset jet. You need find out yourself for your devices setup if works well or not.
EOT
#34
Well it doesn’t work for the ASUS Zenbook S UX391UA :frowning: … not mine
Installed the kernel v19.10 still silence
#35
sudo hwinfo --sound
results please.
#36
thank you
18: PCI 1f.3: 0403 Audio device
  Device: pci 0x9d71
  Revision: 0x21
  IRQ: 126 (45 events)
  Module Alias: "pci:v00008086d00009D71sv00001043sd000010A1bc04sc03i80"
  Driver Info #0:
  Driver Info #1:
#37
SubVendor: pci 0x1043 “ASUSTeK Computer Inc.”
To a FILE https://github.com/torvalds/linux/blob/master/sound/pci/hda/patch_realtek.c
Should be added new line with
near
CC @philm
#38
Thank you for your reply but I’m not a contributor and never compiled the kernel
#39
Can someone please add the following patch to the kernel?
SND_PCI_QUIRK(0x1043, 0x10a1, “ASUS UX391UA”, ALC294_FIXUP_ASUS_SPK),
thank you in advance
