Troubleshooting heroku-cli with yay
I’m working on a Django project which is deployed to Heroku. I use the heroku-cli tool to interface between my local and remote hosts.
Every time I run a command, heroku-cli warns that it is out of date, such as here:
$ heroku login
   Warning: heroku update available from 7.50.0 to 7.54.1.
I can still login with my older version and work on my website but this has been a problem for some time. As you can see, I am 4 point releases away from the latest release. Over the past 6 months or so, I’ve been stuck at v7.50.0 and I watch as heroku-cli reports newer and newer updates become available. To rectify this, I run $ yay -Sy heroku-cli. Here is the output of that command:
› yay -Sy heroku-cli
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1]  heroku-cli-7.56.0-1
  1 heroku-cli                               (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> A
:: Deleting (1/1): /home/<user>/.cache/yay/heroku-cli
:: Downloaded PKGBUILD (1/1): heroku-cli
==> Diffs to show?
==> N
:: (1/1) Parsing SRCINFO: heroku-cli
==> Making package: heroku-cli 7.56.0-1 (Wed 28 Jul 2021 11:18:44 PM EDT)
==> Retrieving sources...
  -> Cloning cli git repo...
Cloning into bare repository '/home/<user>/.cache/yay/heroku-cli/cli'...
remote: Enumerating objects: 77669, done.
remote: Counting objects: 100% (1394/1394), done.
remote: Compressing objects: 100% (730/730), done.
remote: Total 77669 (delta 891), reused 985 (delta 613), pack-reused 76275
Receiving objects: 100% (77669/77669), 23.04 MiB | 14.14 MiB/s, done.
Resolving deltas: 100% (52407/52407), done.
    cli ... Skipped
==> Validating source files with sha512sums...
    cli ... Skipped
==> Making package: heroku-cli 7.56.0-1 (Wed 28 Jul 2021 11:18:50 PM EDT)
  -> Updating cli git repo...
Fetching origin
    cli ... Skipped
    cli ... Skipped
==> Extracting sources...
  -> Creating working copy of cli git repo...
Cloning into 'cli'...
done.
Switched to a new branch 'makepkg'
==> Starting prepare()...
~/.cache/yay/heroku-cli/src ~/.cache/yay/heroku-cli/src
~/.cache/yay/heroku-cli/src/cli ~/.cache/yay/heroku-cli/src ~/.cache/yay/heroku-cli/src
yarn install v1.22.11
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
warning "workspace-aggregator-e7571fed-7512-4721-bf75-0fd034cb3f07 > @heroku-cli/plugin-addons-v5 > @oclif/plugin-legacy > @oclif/command@1.8.0" has unmet peer dependency "@oclif/config@^1".
[5/5] Building fresh packages...
Done in 39.83s.
~/.cache/yay/heroku-cli/src/cli/packages/cli ~/.cache/yay/heroku-cli/src/cli ~/.cache/yay/heroku-cli/src ~/.cache/yay/heroku-cli/src
npm WARN old lockfile
npm WARN old lockfile The package-lock.json file was created with an old version of npm,
npm WARN old lockfile so supplemental metadata must be fetched from the registry.
npm WARN old lockfile This is a one-time fix-up, please be patient...
npm WARN deprecated @types/write-json-file@3.2.1: This is a stub types definition. write-json-file provides its own type definitions, so you do not need this installed.
npm WARN deprecated strip-eof@2.0.0: Renamed to `strip-final-newline` to better represent its functionality.
npm ERR! semver.simplifyRange is not a function
npm ERR! A complete log of this run can be found in:
npm ERR!     /home/<user>/.npm/_logs/2021-07-29T03_20_31_085Z-debug.log
==> ERROR: A failure occurred in prepare().
    Aborting...
error making: heroku-cli
The error at the bottom refers to a log fail located inside my ~/.npm directory. Here are the contents of the full log file: 0 verbose cli [ '/usr/bin/node', '/usr/sbin/npm', 'install' ]1 info using npm@ - Pastebin.com
Is there any other information I could provide to better help you people help me?
Hello @Drone4four :wink:
I don’t use it, but it is maybe better to use a tag instead of a commit id:
source=("git+https://github.com/heroku/cli.git#commit=${_commit_id}")
:arrow_down_small:
source=("git+https://github.com/heroku/cli.git#tag=v${pkgver}")
However… there is also a precompiled binary with the same version:
pamac build heroku-cli-bin
Thanks, @megavolt! This worked. Although I am curious, other than the contents of a new release, what is the difference between the repo packages heroku-cli and heroku-cli-bin? Like, what does -bin indicate?
-bin indicates “binary”. So a pre-compiled or already packaged binary.
heroku-cli-bin: https://github.com/SampsonCrowley/heroku-cli-bin.git
heroku-cli: https://github.com/heroku/cli.git
