I have noticed that after waking up from suspending my system was unresponsive (the touchpad pointer could be moved, but I couldn’t click anywhere or use the keyboard), and I had to force a restart. I’ll investigate if this is due to the update.
What desktop environment? at least give some info when reporting a problem please as it can be relevant. I had a similar issue in the past weeks where clicks were not registering and I thought it was a tool I was using that had an issue but maybe not after all.
Sorry, my post sucked…
Here is my system:
Kernel: 5.17.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=e6c4e28c-1714-4aa0-8378-71e34489645d ro
cryptdevice=UUID=558055a3-e71d-4692-926f-516ae14a27c3:luks-558055a3-e71d-4692-926f-516ae14a27c3
root=/dev/mapper/luks-558055a3-e71d-4692-926f-516ae14a27c3 apparmor=1
security=apparmor udev.log_priority=3 enable_fbc=1 enable_psr=1
disable_power_well=0 mem_sleep_default=deep
resume=/dev/mapper/luks-558055a3-e71d-4692-926f-516ae14a27c3
resume_offset=65067008
Desktop: GNOME v: 42.0 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: Dell product: XPS 15 7590 v: N/A
Mobo: Dell model: 018W12 v: A06 serial: <superuser required> UEFI: Dell
v: 1.14.1 date: 10/11/2021
ID-1: BAT0 charge: 41.8 Wh (43.6%) condition: 95.9/97.0 Wh (98.8%)
volts: 12.1 min: 11.4 model: LGC-LGC8.33 DELL 5XJ280A type: Li-ion
serial: <filter> status: charging
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2343 high: 3098 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2176 2: 2432 3: 2206
4: 3098 5: 2624 6: 2727 7: 1844 8: 1500 9: 1743 10: 2755 11: 2598 12: 2418
bogomips: 62431
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,DP-2,DP-3
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:6723 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: modesetting gpu: i915
display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x2160 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: Samsung 0xa029 built: 2019 res: 3840x2160 hz: 60
dpi: 284 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 3840x2160
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Sound Server-1: ALSA v: k5.17.4-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.50 running: no
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 3b:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:11 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 8 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 236.64 GiB (49.6%)
model: PC SN730 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 11150012 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 355.94 GiB size: 349.36 GiB (98.15%)
used: 236.64 GiB (67.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-558055a3-e71d-4692-926f-516ae14a27c3
used: 508 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: file size: 15 GiB used: 300 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 51.0 C pch: 42.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 445 Uptime: 7h 10m wakeups: 14 Memory: 15.27 GiB
used: 10.62 GiB (69.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1880 pacman: 1840 lib: 496 flatpak: 32
snap: 8 Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.15
I have to say that the issue has not occured again (with 3-4 suspensions in the meantime) since yesterday.
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
I see the common thing we have is the kernel so maybe the kernel 5.17 is the culprit here (I use KDE). The issue I had after going back to the computer the next day (after I sleep) was the clicks not registering at all (but I could move the mouse, highlight icons in the taskbar when hovering them), and unplugging/plugging the mouse fixed the issue. In your case the keyboard wasn’t working but mine was, but on your laptop the keyboard/trackpad is maybe one peripheral instead of two like on my desktop PC.
I’ll try to investigate the issue too, maybe it is related to sleeping/waking up the computer. I thought it was Input Remapper tool that was the culprit on my side but maybe not, now you said you had similar issue.
I guess we could continue in a dedicated thread if needed instead of flooding this thread.
Good idea.
