:: Searching AUR for updates…
→ kvantum-theme-matchama: local (20191118-1) is newer than AUR (r265.8525e05-2)
→ Missing AUR Packages: linux513 yaourt
Why do these messages appear?
linux 513 is eol, so remove it
and the package that is newer can be ignored, or you can downgrade it if it causes issues
Thanks
yaourt has finally be removed
A message appeared while uninstalling linux513. This is fine?
sudo yay -R linux513
done
yes it is
it is - except that you should not use sudo
with yay
yay
will prompt you for admin password when needed
Not quite. One should always use Manjaro Settings Manager or MHWD to install or remove kernels; i.e.,
sudo mhwd-kernel -r linux513
