After upgrade no display
I updagraded my manjaro 2 days ago. I was using 5.9 kernel and now upgraded to 5.10 to fix the issue. But, it is still not working. I was using LXDM display manager. My Xorg log file says no devices detected.
inxi details are given below
  Kernel: 5.10.79-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=2e125e57-9a9f-4c68-b7ce-d560609b0c5c ro quiet
  resume=UUID=4114ab03-32f8-46eb-b19f-e926b9b1dc46 udev.log_priority=3
  Console: tty 2 DM: LXDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: ROG MAXIMUS XI HERO (WI-FI) v: Rev 1.xx
  serial: <superuser required> UEFI: American Megatrends v: 1401
  date: 11/26/2019
  Info: 8-Core model: Intel Core i7-9700K bits: 64 type: MCP arch: Kaby Lake
  note: check family: 6 model-id: 9E (158) stepping: D (13) microcode: EA
  cache: L1: 512 KiB L2: 2 MiB L3: 12 MiB
  flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  bogomips: 57616
  Speed: 2377 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 2377 2: 1779
  3: 1175 4: 3663 5: 2870 6: 2509 7: 2525 8: 2452
  Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
  Type: srbds mitigation: TSX disabled
  Device-1: NVIDIA TU102 [TITAN RTX] driver: N/A alternate: nouveau
  bus-ID: 01:00.0 chip-ID: 10de:1e02 class-ID: 0300
  Display: server: X.org 1.21.1.1 driver: loaded: N/A failed: nvidia
  tty: 128x48
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  Device-2: NVIDIA TU102 High Definition Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.79-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 15.0 running: no
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  IF: wlan0 state: down mac: <filter>
  Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
  port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: not found
  Local Storage: total: 4.55 TiB used: 111.42 GiB (2.4%)
  model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
  rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
  logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
  rev: 1A01
  ID-1: / raw-size: 922.42 GiB size: 906.94 GiB (98.32%)
  used: 111.42 GiB (12.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
  maj-min: 259:2
  used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
  maj-min: 259:1
  dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 163 Uptime: 57m wakeups: 1 Memory: 62.73 GiB
  used: 725.6 MiB (1.1%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: pacman: 636 lib: 136 Shell: Bash (login) v: 5.1.8
  running-in: tty 2 inxi: 3.3.09
Hello @hanstech and welcome :wink:
Looks like you need to install the nvidia drivers since the nouveau driver has no support for your card yet: Configure Graphics Cards - Manjaro
I tried
sudo mhwd -a pci free 0300
It installed video-linux package, I restarted the machine but still same error.
  date: 11/26/2019
  bogomips: 57616
  Speed: 2007 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 2007 2: 1009
  3: 1275 4: 899 5: 1140 6: 1196 7: 4117 8: 3869
  tty: 128x48
  Message: Advanced graphics data unavailable in console. Try -G --display
  Local Storage: total: 4.55 TiB used: 111.66 GiB (2.4%)
  rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
  rev: 1A01
  used: 111.66 GiB (12.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
  maj-min: 259:2
  maj-min: 259:1
  Processes: 166 Uptime: 7m wakeups: 1 Memory: 62.73 GiB
  used: 732.1 MiB (1.1%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: pacman: 645 lib: 138 Shell: Bash (login) v: 5.1.8
Change the command to this:
So it will install the nvidia driver, not the nouveau.
I just said: the nouveau driver has no support for your card
  1. nouveau → free
  2. nvidia → proprietary/nonfree
Thanks. It is fixed now :slight_smile:
