After updating to gnome48, open vlc and a black background block appears
This black background will soon disappear and vlc’s title bar will be rendered.
This is likely caused by VLC being a qt-based application and gnome want to apply client side decorations which doesn’t exist with a qt-based app, creating the black background which will later be repainted by the shell.
I don’t know if there is a workaround - one guess is that it could be theme related, if you are using a custom theme.
I’m just doing the personalization here, gnome47 is fine, it’s just something that comes with this update.
I don’t know - gnome is quite unpredictable - if I were actually using gnome - I would probably use a gnome based media player - and thus avoiding theme issues all along.
Qt based applications with the Gnome desktop is a not a good combination, I am sorry - is how it is.
Thank you for your attention to this issue, which gives me a little warmth and comfort. I believe that the developers of VLC software will definitely follow up, give them a little time, everything will become better and better!
It may be related to this issue:
Update:
In case somebody wants to try the GTK4 fix until we get a official update, I’ve created a patched PKGBUILD.
1:
git clone https://gitlab.archlinux.org/archlinux/packaging/packages/gtk4.git
2: replace the PKGBUILD with this one:
PKGBUILD
# Maintainer: Jan Alexander Steffens (heftig) <heftig@archlinux.org>
# Maintainer: Fabian Bornschein <fabiscafe@archlinux.org>
pkgbase=gtk4
pkgname=(
  gtk4
  gtk4-demos
  gtk4-docs
  gtk-update-icon-cache
pkgver=4.18.4
pkgrel=2
epoch=1
pkgdesc="GObject-based multi-platform GUI toolkit"
url="https://www.gtk.org/"
arch=(x86_64)
license=(LGPL-2.1-or-later)
depends=(
  adwaita-icon-theme
  at-spi2-core
  cairo
  cantarell-fonts
  dconf
  desktop-file-utils
  fontconfig
  fribidi
  gcc-libs
  gdk-pixbuf2
  glib2
  graphene
  gst-plugins-bad-libs
  harfbuzz
  iso-codes
  libcloudproviders
  libcolord
  libcups
  libegl
  libepoxy
  libgl
  libjpeg-turbo
  libpng
  librsvg
  libtiff
  libx11
  libxcursor
  libxdamage
  libxext
  libxfixes
  libxi
  libxinerama
  libxkbcommon
  libxrandr
  libxrender
  pango
  shared-mime-info
  tinysparql
  wayland
makedepends=(
  docbook-xsl
  gi-docgen
  git
  glib2-devel
  gobject-introspection
  libsysprof-capture
  meson
  python-docutils
  python-gobject
  sassc
  shaderc
  vulkan-headers
  wayland-protocols
checkdepends=(
  gst-plugin-pipewire
  gst-plugins-base
  mutter
  noto-fonts
  pipewire
  python-pydbus
  vulkan-swrast
  weston
  wireplumber
source=(
  "git+https://gitlab.gnome.org/GNOME/gtk.git#tag=$pkgver"
  gtk-update-icon-cache.{hook,script}
  gtk4-querymodules.{hook,script}
  0001-HACK-Don-t-use-objcopy-for-resource-embedding.patch
  "0002-8459.patch::https://gitlab.gnome.org/GNOME/gtk/-/merge_requests/8459.patch"
b2sums=('c27d0cd2381ca94ee6bbb08ad978cd2f352cab90c24296483b20c6736d964baea0f78f4def0e5790995b5b0d4cb68f47e0df6d9feccf33fa797aca0d93e7b276'
        '136bdb410c46daf769175e8e8837286576391797a4762b8cf388217e893dd6c5087c5c91c347cbdf7d3e9dcd2c978c2fb275b5af1f3425c9f7979fbc65a81324'
        '6bcd839ef82296d864587e0cc7acc0145bdea8e5235af304747cf3c0e564c2757cc67c0373dc044bec83dccfc57dc899546c2fccea96cff2bba22f09978a3814'
        'dd589bd1ad2b13f0e06f6899776a083f20a1aac24d4308d666ffd0d1cff38457b8257b8366f92e767b4233b3d86b6b54fa50339faf84c4801a824986366dce30'
        '4b90eb8d582509b09aab401313d4399cc139ad21b5dd7d45d79860d0764c7494c60714e0794e09823e51d1894ac032a994f27d79d1499abf24ee6f59bdb0c243'
        '15eb7b0083bc673236658cb5542bd21f08a545aaaef1a5bb4573eea30ce0f813f327de91a76ce8f7ca44d4948fafa6f5f388d117280fcc67c278e34d59edded0'
        'c4a1f28bbdeb88db65ab5afc309215a345607fc476babccd2a4c2c0926a56d8b4aedfdd26f64b11679911c5b05676c8c6f023b6ffcad2187a8ff527f651aab0e')
prepare() {
  cd gtk
  # Allow -fcf-protection to work
  # https://gitlab.gnome.org/GNOME/gtk/-/issues/6153
  git apply -3 ../0001-HACK-Don-t-use-objcopy-for-resource-embedding.patch
  # https://gitlab.gnome.org/GNOME/gtk/-/merge_requests/8393
  git apply -3 ../0002-8459.patch
build() {
  local meson_options=(
    -D broadway-backend=true
    -D cloudproviders=enabled
    -D colord=enabled
    -D documentation=true
    -D man-pages=true
    -D sysprof=enabled
    -D tracker=enabled
  CFLAGS+=" -DG_DISABLE_CAST_CHECKS"
  arch-meson gtk build "${meson_options[@]}"
  meson compile -C build
check() (
  export XDG_RUNTIME_DIR="$PWD/runtime-dir"
  mkdir -p -m 700 "$XDG_RUNTIME_DIR"
  export WAYLAND_DISPLAY=wl-$pkgbase-$RANDOM
  weston --backend=headless --socket=$WAYLAND_DISPLAY --idle-time=0 &
  _w=$!
  trap "kill $_w; wait" EXIT
  # Test: GTK / templates fails - ignore it for now.
  sed -i "s/{ 'name': 'templates' }/#{ 'name': 'templates' }/g" gtk/testsuite/gtk/meson.build
  # Comparison tests fail, because thes depend on driver and how mesa was build
  # https://gitlab.gnome.org/GNOME/gtk/-/issues/6383
  meson test -C build --print-errorlogs --no-suite=headless --timeout-multiplier=3 ||:
_pick() {
  local p="$1" f d; shift
  for f; do
    d="$srcdir/$p/${f#$pkgdir/}"
    mkdir -p "$(dirname "$d")"
    mv "$f" "$d"
    rmdir -p --ignore-fail-on-non-empty "$(dirname "$f")"
  done
package_gtk4() {
  depends+=(
    bash
    glibc
    gst-plugins-base-libs
    gstreamer
    vulkan-icd-loader
  optdepends=('evince: Default print preview command')
  provides=(libgtk-4.so)
  meson install -C build --destdir "$pkgdir"
  install -Dm644 /dev/stdin "$pkgdir/usr/share/gtk-4.0/settings.ini" <<END
[Settings]
gtk-icon-theme-name = Adwaita
gtk-theme-name = Adwaita
gtk-font-name = Cantarell 11
END
  install -Dt "$pkgdir/usr/share/libalpm/hooks" -m644 gtk4-querymodules.hook
  install -D gtk4-querymodules.script "$pkgdir/usr/share/libalpm/scripts/gtk4-querymodules"
  cd "$pkgdir"
  _pick demo usr/bin/gtk4-{demo,demo-application,node-editor,print-editor,widget-factory}
  _pick demo usr/share/applications/org.gtk.{Demo4,PrintEditor4,WidgetFactory4,gtk4.NodeEditor}.desktop
  _pick demo usr/share/glib-2.0/schemas/org.gtk.Demo4.gschema.xml
  _pick demo usr/share/icons/hicolor/*/apps/org.gtk.{Demo4,PrintEditor4,WidgetFactory4,gtk4.NodeEditor}[-.]*
  _pick demo usr/share/man/man1/gtk4-{demo,demo-application,node-editor,widget-factory}.1
  _pick demo usr/share/metainfo/org.gtk.{Demo4,PrintEditor4,WidgetFactory4,gtk4.NodeEditor}.appdata.xml
  _pick docs usr/share/doc
  # Built by GTK 4, shared with GTK 3
  _pick guic usr/bin/gtk4-update-icon-cache
  _pick guic usr/share/man/man1/gtk4-update-icon-cache.1
package_gtk4-demos() {
  pkgdesc+=" (demo applications)"
  depends=(
    cairo
    dconf
    gdk-pixbuf2
    glib2
    glibc
    graphene
    gtk4
    harfbuzz
    hicolor-icon-theme
    libepoxy
    librsvg
    pango
  mv demo/* "$pkgdir"
package_gtk4-docs() {
  pkgdesc+=" (documentation)"
  depends=()
  mv docs/* "$pkgdir"
package_gtk-update-icon-cache() {
  pkgdesc="GTK icon cache updater"
  depends=(
    bash
    gdk-pixbuf2
    glib2
    glibc
    hicolor-icon-theme
    librsvg
  mv guic/* "$pkgdir"
  ln -sr "$pkgdir"/usr/bin/gtk{4,}-update-icon-cache
  ln -sr "$pkgdir"/usr/share/man/man1/gtk{4,}-update-icon-cache.1
  install -Dt "$pkgdir/usr/share/libalpm/hooks" -m644 gtk-update-icon-cache.hook
  install -D gtk-update-icon-cache.script \
    "$pkgdir/usr/share/libalpm/scripts/gtk-update-icon-cache"
# vim:set sw=2 sts=-1 et:
3: run makepkg -src or similar
4: sudo pacman -U /path/to/gtk4 /path/to/gtk-update-icon-cache etc.
5: reboot and test :wink:
It fixes the issue in my case with 200% scaling.
