I’ve reinstalled my operating system 3-4 times since getting it, as I thought I had a problem with the screen no longer turning on whenever I did updates.
I just realized today, however. My screen isn’t dying at all, the screen does turn on, the brightness is just so low that it’s impossible to use. Under the right lighting I can just about see the time and swipe up the keypad for the passcode, but that’s it.
Whenever I update my phone, my brightness goes down to the minimum. Now that I know the issue, I fixed it by blindly unlocking, typing in the passcode, pulling down the menu, and spending 2 minutes swiping randomly left to right until I managed to get the brightness slider.
Could the minimum brightness be updated, so users are never in a position the phone might become almost unusable?
On standby to provide more information if required.
Oh, actually on the side, could it still be worth reconsidering the minimum brightness of the device in general?
Or at least limiting it until an advanced option is toggled to allow more flexibility?
I recall the first time I ever used the phone as well (exploring settings etc.) I screwed myself over when I was testing the minimum and maximum brightness. ^-^’
I tried disabling /usr/share/lib/udev/rules.d/10-proximity.rules but it didn’t help.
EDIT: And here (ThreadId 12481 on pine 64 forums (still can’t link there ) is a thread about the rubber thingy, which is missing on my phone (maybe I lost it, when changing the motherboard).
This isn’t a manjaro specific issue, as I’ve tried GloDroid which also allows for the brightness to be set to 0. It seems to be a kernel related thing which needs to be solved once and for all.
