Hi, I am quite new to Linux in general and yesterday I installed Manjaro, I made some updates and when I reboot the pc, I stopped being able to log in. What I did was literally this:
Go to the ‘Manjaro Settings Manager’ application and install the Nvidia Drivers (which by the way, I got this on the console: ‘gpg: key 786C63F330D7CB92: no user id for key’).
Reset the PC and log in … So far so good
Then enter the ‘Add/Remove Software’ application and apply the updates that were available.
Reset the PC and then here the problems began.
After doing exactly that then I stopped being able to login. I was trying to login and the screen puts black as if I was going to enter the desktop and then the login reapears.
Here I show you the output of the command “inxi --admin --verbosity = 7 --filter --no-host --width”
Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0e5d26bf-7e55-45db-9023-0f10a30556af rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 s
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: Acer product: Predator G3-572 v: V1.10 serial: <filter>
Mobo: KBL model: Sienta_KLS v: V1.10 serial: <filter> UEFI: Insyde v: 1.10
date: 08/22/2017
ID-1: BAT1 charge: 36.5 Wh (100.0%) condition: 36.5/48.9 Wh (74.5%)
volts: 16.6 min: 15.2 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: Full
RAM: total: 15.52 GiB used: 2.13 GiB (13.7%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 2400 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Micron part-no: 8ATF1G64HZ-2G3B1
serial: <filter>
Device-2: ChannelB-DIMM0 size: 8 GiB speed: 2400 MT/s type: DDR4
serial: <filter>
Info: Quad Core model: Intel Core i7-7700HQ socket: U3E1 bits: 64
type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9
microcode: EA cache: L1: 256 KiB L2: 6 MiB L3: 6 MiB bogomips: 44817
Speed: 900 MHz min/max: 800/3800 MHz base/boost: 3400/8300 volts: 1.0 V
ext-clock: 100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900
6: 901 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c20
class-ID: 0300
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-9:4
chip-ID: 04f2:b5f7 class-ID: 0e02
Display: server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171
class-ID: 0403
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 4000 bus-ID: 02:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 03:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f1 state: down mac: <filter>
IF-ID-1: enp0s20f0u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
chip-ID: 04ca:3016 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 9.61 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV512TBN
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: A020 scheme: GPT
ID-1: / raw-size: 93.49 GiB size: 91.47 GiB (97.83%) used: 9.55 GiB (10.4%)
fs: ext4 block-size: 4096 B dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 0e5d26bf-7e55-45db-9023-0f10a30556af
used: 53.3 MiB (55.5%) fs: vfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1 label: ESP uuid: 5A99-0040
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 382.33 GiB fs: ntfs label: N/A
uuid: E0B60C97B60C6FF8
ID-3: /dev/sda4 maj-min: 8:4 size: 1024 MiB fs: ntfs label: Recovery
uuid: 6AA6A089A6A056FB
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: Xiaomi Mi/Redmi series (RNDIS + ADB) type: CDC-Data
driver: rndis_host interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 2717:ff88 class-ID: 0a00 serial: <filter>
Device-2: 1-7:3 info: Lite-On type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 04ca:3016 class-ID: e001
Device-3: 1-9:4 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b5f7
class-ID: 0e02
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 55.0 C mobo: 29.8 C
Processes: 245 Uptime: 1h 26m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1142 lib: 299
flatpak: 0 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8
running-in: gnome-terminal inxi: 3.3.06
the output of the command “sudo dmesg --level emerg,alert,crit,err,warn”:
[ 0.128095] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.128095] #5 #6 #7
[ 0.131829] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.496281] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.498924] resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:00 [mem 0xfdb00000-0xfdffffff]
[ 0.498928] caller pmc_core_probe+0x7e/0x410 mapping multiple BARs
[ 1.197665] usb: port power management may be unreliable
[ 2.042823] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.042825] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.042827] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.042829] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.062992] i2c_hid i2c-SYNA7DB5:01: supply vdd not found, using dummy regulator
[ 2.063012] i2c_hid i2c-SYNA7DB5:01: supply vddl not found, using dummy regulator
[ 2.129363] r8169 0000:03:00.1: can't disable ASPM; OS doesn't have ASPM control
[ 2.154638] nvidia: loading out-of-tree module taints kernel.
[ 2.154651] nvidia: module license 'NVIDIA' taints kernel.
[ 2.154652] Disabling lock debugging due to kernel taint
[ 2.374702] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.63.01 Tue Aug 3 20:44:16 UTC 2021
[ 3.987932] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 8.567716] kauditd_printk_skb: 15 callbacks suppressed
[ 4368.516214] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[ 4370.348526] kauditd_printk_skb: 59 callbacks suppressed
[ 4379.132148] kauditd_printk_skb: 5 callbacks suppressed
[ 4393.567471] kauditd_printk_skb: 12 callbacks suppressed
I must also say that when I edit the boot parameters (when the grub screen) and add the letter s
to the end of the line that starts with ‘linux’ word and I enter the rescue mode, log in and immediately exit I can incredibly login in the GUI and enter the desktop. Hence I assume that it has something to do with PAM that I read that it has deprecated modules and I know that it has to do with the login (I only know that jjj). So what can I do to solve this? I will greatly appreciate the help. Thanks in advance.
