Hi,
some days ago I updated my Manjaro and after a reboot my Xorg wont start. Im not sure if Xorg is the problem or my Nvidia driver.
I tinkered a little bit but didnt find a solution. Do you know anything?
GPU: NVIDIA GeForce GTX 1660 Super
CPU: AMD Ryzen 7 2700X Eight-Core Processor
Thank you!
Journalctl errors:
Feb 09 22:01:34 SCHNELLO kernel: Linux version 5.15.89-1-MANJARO (builduser@fv-az617-851) (gcc (GCC) 12.2.1 20230111, GNU ld (GNU Binutils) 2.40) #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: Current Operating System: Linux SCHNELLO 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) Failed to load module "nv" (module does not exist, 0)
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) [drm] Failed to open DRM device for (null): -2
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) [drm] Failed to open DRM device for pci:0000:09:00.0: -19
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) Screen 0 deleted because of no matching config section.
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) Device(s) detected, but none match those in the config file.
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) no screens found(EE)
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Feb 09 22:01:37 SCHNELLO /usr/lib/gdm-x-session[1186]: (EE) Server terminated with error (1). Closing log file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: Current Operating System: Linux SCHNELLO 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) Failed to load module "nv" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) [drm] Failed to open DRM device for (null): -2
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) [drm] Failed to open DRM device for pci:0000:09:00.0: -19
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) Screen 0 deleted because of no matching config section.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) Device(s) detected, but none match those in the config file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) no screens found(EE)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1480]: (EE) Server terminated with error (1). Closing log file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: Current Operating System: Linux SCHNELLO 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) Failed to load module "nv" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) [drm] Failed to open DRM device for (null): -2
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) [drm] Failed to open DRM device for pci:0000:09:00.0: -19
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) Screen 0 deleted because of no matching config section.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) Device(s) detected, but none match those in the config file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) no screens found(EE)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1486]: (EE) Server terminated with error (1). Closing log file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: Current Operating System: Linux SCHNELLO 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) Failed to load module "nv" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) [drm] Failed to open DRM device for (null): -2
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) [drm] Failed to open DRM device for pci:0000:09:00.0: -19
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) Screen 0 deleted because of no matching config section.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) Device(s) detected, but none match those in the config file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) no screens found(EE)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1492]: (EE) Server terminated with error (1). Closing log file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: Current Operating System: Linux SCHNELLO 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) Failed to load module "nv" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) [drm] Failed to open DRM device for (null): -2
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) [drm] Failed to open DRM device for pci:0000:09:00.0: -19
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) Screen 0 deleted because of no matching config section.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) Device(s) detected, but none match those in the config file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) no screens found(EE)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1498]: (EE) Server terminated with error (1). Closing log file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: Current Operating System: Linux SCHNELLO 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) Failed to load module "nv" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) [drm] Failed to open DRM device for (null): -2
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) [drm] Failed to open DRM device for pci:0000:09:00.0: -19
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) Screen 0 deleted because of no matching config section.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) Device(s) detected, but none match those in the config file.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) no screens found(EE)
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Feb 09 22:01:48 SCHNELLO /usr/lib/gdm-x-session[1504]: (EE) Server terminated with error (1). Closing log file.
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: Current Operating System: Linux SCHNELLO 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) Error systemd-logind returned paused fd for drm node
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) Failed to load module "nv" (module does not exist, 0)
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) [drm] Failed to open DRM device for pci:0000:09:00.0: -2
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) Screen 0 deleted because of no matching config section.
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) Device(s) detected, but none match those in the config file.
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) no screens found(EE)
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Feb 09 22:07:13 SCHNELLO /usr/lib/gdm-x-session[1840]: (EE) Server terminated with error (1). Closing log file.
Xorg Log (only errors):
[ 343.087] Current Operating System: Linux SCHNELLO 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
[ 343.089] (EE) Error systemd-logind returned paused fd for drm node
[ 343.100] (EE) Failed to load module "nv" (module does not exist, 0)
[ 343.101] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 343.102] (EE) [drm] Failed to open DRM device for pci:0000:09:00.0: -2
[ 343.103] (EE) Screen 0 deleted because of no matching config section.
[ 343.103] (EE) Device(s) detected, but none match those in the config file.
[ 343.103] (EE)
[ 343.103] (EE) no screens found(EE)
[ 343.103] (EE)
[ 343.103] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 343.103] (EE)
[ 343.112] (EE) Server terminated with error (1). Closing log file.
