When run chromium
chromium
/usr/lib/chromium/chromium: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.31’ not found (required by /usr/lib/chromium/chromium)
When run chromium
chromium
If you are on stable branch, your best option is to switch to testing or Unstable branches. Or wait until Stable catches up.
pacman -Qo /usr/lib/libstdc++.so.6
/usr/lib/libstdc++.so.6 is owned by gcc-libs 13.1.1-1
gcc-libs:
stable12.2.1-2
testing13.1.1-1
unstable13.1.1-1
I am in the stable branch stable12.2.1-2
How do I switch to testing?
How long do you have to wait for the result?
In addition, what programs other than Chromium do not solve this problem?
Please give me download link glibc 13.1
I wand download and offline install
Partial updates are not supported. Manjaro is a curated, rolling release, so Testing will become Stable at some, unpredictable point. Take a look here:
Welcome to the forum!
If you’re using the stable branch, you should have chromium
112.0.5615.165-1 which was built with gcc
12.2.1. gcc
13.1.1 is only in the testing and unstable branches.
It appears you are in an unsupported partial upgrade state. Please see Pacman-mirrors - Manjaro
Thank you
I’m using ungoogled 113.0.56
Yep, that is why you have the issue. Here is some information regarding the AUR:
Version ungooled 112.0.5615.165
Where can I download the ungooled 112.0.5615.165 version?
I update form aur
That really isn’t a great idea as the current version has the latest security updates, but if you must…
Thank you
