After update no Audio
Hi! As the title says, I lost my audio after an update.
As it seems I have two Audio cards:
inxi -SMxxA
  Host: whiteknight Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 13.1.1 Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10
    wm: kwin_x11 dm: 1: LightDM note: stopped 2: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7B79 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: X470 GAMING PRO (MS-7B79) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.90
    date: 03/07/2019
  Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
    bus-ID: 1d:00.1 chip-ID: 10de:1aef
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
    bus-ID: 1f:00.3 chip-ID: 1022:1457
  API: ALSA v: k6.4.6-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 0.3.75 status: off with: pipewire-media-session
    status: active
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module
> cat /proc/asound/cards
 0 [NVidia         ]: HDA-Intel - HDA NVidia
                      HDA NVidia at 0xf7080000 irq 72
 1 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xf7800000 irq 74
Audio was working for years and I have not changed any Hardware.
Can someone tell me how and where should I start to find the problem? Thanks
What do pactl info and pactl list cards short print?
If your machine is still using the device that was working previously it might be worth testing if sound returns after switching between HiFi channels, my audio vanished after an update a couple days ago and that fixed it.
I normally used HiFi 7.1 channels which suddenly gave no output, after switching to HiFi 2.0 channels and then straight back to 7.1 sound was working again.
pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 13
Tile Size: 65472
User Name: steve
Host Name: whiteknight
Server Name: pulseaudio
Server Version: 16.1
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_1f_00.3.iec958-stereo
Default Source: alsa_output.pci-0000_1f_00.3.iec958-stereo.monitor
Cookie: c310:8812
0       alsa_card.pci-0000_1d_00.1      module-alsa-card.c
1       alsa_card.pci-0000_1f_00.3      module-alsa-card.c
I found the problem!
In the device selection (loudspeaker symbol in task bar) the output was set to SPDIF.
I have no idea how is that happened as I have not opened this menu for years… Now I set it back to HDMI (my Monitor has speakers) and now I have sound.
Thanks for your help and suggestions!
